This release is a minor bug fix update that has been in ALPHA and BETA for three weeks without incident. It has a couple of minor fixes to 02_05_04 which has been out since mid February with only the fixed issue surfacing in a couple of sites. The improvements over 02_05_02 are substantial.
I’ll start replying here. This appears to be the appropriate thread. #2 was purchased back in early December. Unit 1 in late January or early February of this year
#2 went to steady red. Power cycled it. Then it went to red green green but cannot find IP address when looking for iota2.local
Auto updated last night.
Now, graph+ does not work
error log from consule
Loading failed for the with source “https://cdn.jsdelivr.net/npm/jquery.flot@0.8.3/jquery.flot.time.min.js”.
Ideas ?
What released did you update from?
update was from 2-5-2
That component has been loaded from the jsdelivr cdn url since inception. It is, however, the only one from that cdn. All of the others come from cloudflare.
I am dubious about this being your problem. Can you post a screenshot of the entire window including the js debugger portion with the error message?
What is the difference between the first and second? I see you are trying to run a saved graph. Does it work to just graph something without loading a saved graph?
Regarding the failed cdn load, what country are you located in?
Difference between first and second image is at the bottom
first one has the “debugger” frame open
second has the “console” frame open ( which shows the error "Loading failed for the with source “https://cdn.jsdelivr.net/npm/jquery.flot@0.8.3/jquery.flot.time.min.js”.
Not doing anything fancy with the graphs+, just trying to graph anything. Nothing will graph, no data, no saved graph.
The window takes quite a few seconds to open as well. ( never used to. no changes to my PC either )
Also, here is no frame around the “graph box”
I did wonder about that. I am in Aus
I guess it is possible an internet issue, not being able to reach cloudfare or whatnot
Just seems very suspicious that it has only happend with the update ( it was working fine yesterday )
Not ruling that out, but that component load has not changed, so it’s more complicated at best. A lot of CDN loads from cloudflare preceed that jsdelivr.net script. I believe cloudflare would serve that stuff from a server on your continent, if not in you city or at your ISP. jsdelivr.net I have no idea. I will search for another source tomorrow. There are a ton of time-pickers available for jquery, and cdn support is scattered all over. Potentially I could put it on iotawatt.com which is cached by cloudflare, but not sure it’s the problem yet.
I believe you updated sometime after 3:00pm EDT which would be around 8:00am down there. If you change to auto-update MAJOR you will return to 02_05_02. I’d be curious if that works.
i’ll try going back to 05-05-02
I just set back to “major”
will this happen by itself or do i need to physically do something ?
Should be done by now
Ok IotaWatt status says we are back at 02-05-02
graphs still not working at all and the page is very slow to load (same as 02-05-02)
log
3/23/20 18:59:51z Real Time Clock is running. Unix time 1584989991
3/23/20 18:59:51z Reset reason: Software/System restart
3/23/20 18:59:51z Trace: 18:3, 18:4, 18:5, 1:6, 1:3, 1:4, 1:5[22], 22:0, 22:1, 22:0, 22:80, 22:85, 22:2, 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:1[4], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:7
3/23/20 18:59:51z ESP8266 ChipID: 6145634
3/23/20 18:59:51z IoTaWatt 5.0, Firmware version 02_05_05
3/23/20 18:59:51z Updater: Installing update files for version 02_05_05
3/23/20 18:59:51z Updater: Installing GRAPH.HTM
3/23/20 18:59:51z Updater: Installing GRAPH.JS
3/23/20 18:59:51z Updater: Installing GRAPH2.HTM
3/23/20 18:59:51z Updater: Installing GRAPH2.JS
3/23/20 18:59:52z Updater: Installing INDEX.HTM
3/23/20 18:59:54z Updater: Installing TABLES.TXT
3/23/20 18:59:54z Updater: Installing CNFSTYLE.CSS
3/23/20 18:59:54z Updater: Installing EDIT.HTM
3/23/20 18:59:54z Updater: Installation complete.
3/23/20 18:59:55z SPIFFS mounted.
3/24/20 02:59:55 Local time zone: +8:00
3/24/20 02:59:55 device name: IotaWatt
3/24/20 02:59:55 LLMNR responder started for hostname IotaWatt
3/24/20 02:59:55 HTTP server started
3/24/20 02:59:55 timeSync: service started.
3/24/20 02:59:55 statService: started.
3/24/20 02:59:55 dataLog: service started.
3/24/20 02:59:55 dataLog: Last log entry 03/24/20 02:59:20
3/24/20 02:59:56 historyLog: service started.
3/24/20 02:59:56 historyLog: Last log entry 03/24/20 02:59:00
3/24/20 02:59:59 WiFi connected. SSID=SpeedyDave, IP=192.168.1.106, channel=6, RSSI -68db
3/24/20 02:59:59 Updater: service started. Auto-update class is MINOR
3/24/20 03:00:00 Updater: Auto-update is current for class MINOR.
3/24/20 03:00:05 PVoutput: started
3/24/20 03:00:05 PVoutput: System Speedy Dave’s, interval 5, donator mode
3/24/20 03:00:06 PVoutput: Start status beginning 03/24/20 02:55:00
3/24/20 11:40:29 Updater: Auto-update class changed to MAJOR
3/24/20 11:40:30 Updater: Update from 02_05_05 to 02_05_02
3/24/20 11:40:30 Updater: download 02_05_02
3/24/20 11:40:37 Updater: Release downloaded 7337ms, size 762848
3/24/20 11:40:49 Updater: signature verified
3/24/20 11:40:57 Updater: firmware upgraded to version 02_05_02
3/24/20 11:40:57 Updater: Firmware updated, restarting.
3/24/20 03:41:04z Real Time Clock is running. Unix time 1585021264
3/24/20 03:41:04z Reset reason: Software/System restart
3/24/20 03:41:04z Trace: 1:3, 1:4, 1:5[22], 22:0, 22:1, 22:0, 22:80, 22:85, 22:2, 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:7
3/24/20 03:41:04z ESP8266 ChipID: 6145634
3/24/20 03:41:04z IoTaWatt 5.0, Firmware version 02_05_02
3/24/20 03:41:04z Updater: Installing update files for version 02_05_02
3/24/20 03:41:04z Updater: Installing GRAPH.JS
3/24/20 03:41:04z Updater: Installing GRAPH2.HTM
3/24/20 03:41:04z Updater: Installing GRAPH2.JS
3/24/20 03:41:05z Updater: Installing INDEX.HTM
3/24/20 03:41:07z Updater: Installing TABLES.TXT
3/24/20 03:41:08z Updater: Installing CNFSTYLE.CSS
3/24/20 03:41:08z Updater: Installing EDIT.HTM
3/24/20 03:41:08z Updater: Installing GRAPH.HTM
3/24/20 03:41:08z Updater: Installation complete.
3/24/20 03:41:08z SPIFFS mounted.
3/24/20 11:41:10 Local time zone: +8:00
3/24/20 11:41:10 device name: IotaWatt
3/24/20 11:41:10 MDNS responder started for hostname IotaWatt
3/24/20 11:41:10 LLMNR responder started for hostname IotaWatt
3/24/20 11:41:10 HTTP server started
3/24/20 11:41:10 timeSync: service started.
3/24/20 11:41:10 statService: started.
3/24/20 11:41:10 Updater: service started. Auto-update class is MAJOR
3/24/20 11:41:11 dataLog: service started.
3/24/20 11:41:11 dataLog: Last log entry 03/24/20 11:40:35
3/24/20 11:41:11 WiFi connected. SSID=SpeedyDave, IP=192.168.1.106, channel=6, RSSI -70db
3/24/20 11:41:12 Updater: Auto-update is current for class MAJOR.
3/24/20 11:42:10 historyLog: service started.
3/24/20 11:42:10 historyLog: Last log entry 03/24/20 11:40:00
3/24/20 11:42:10 PVoutput: started
3/24/20 11:42:11 PVoutput: System Speedy Dave’s, interval 5, donator mode
3/24/20 11:42:12 PVoutput: Start status beginning 03/24/20 11:40:00
still getting
and
Error: Time mode requires the flot.time plugin.
in the debug frame
So it’s nothing to do with 02_05_05. What’s the status with the pandemic down there? Do you think it is affecting internet speed to locations off the continent?
Everyone here is home watching netflicks.
that is probably it.
we are in lock down here with only essential service and travel allowed.
kids are out of school
no toilet paper, rice, sugar, flour, pasta, tinned foods etc.
pretty bad actually, and getting worse
we had 1 million people lose their jobs yesterday …
Heard you guys are in really big trouble due to all the fake news saying it is just like the flu.
