This is a repackaged 02_05_07 with only some new CTs added to the tables.
As there are no other changes from 02_05_07, I expect to fast track this to completely replace it.
UPDATE 4/23/2020 Added BETA
UPDATE 4/24/2020 Added MINOR
I am currently seeing the following recurring message on both of my IoTaWatt devices.
Updater: Unrecognized auto-update class MINOR.
Here’s a snippet of the log from one of my IoTaWatt devices (scroll to the bottom.)
4/24/20 17:37:12 Updater: Update from 02_05_07 to 02_05_08
4/24/20 17:37:12 Updater: download 02_05_08
4/24/20 17:37:20 Updater: Release downloaded 7963ms, size 803592
4/24/20 17:37:30 Updater: signature verified
4/24/20 17:37:38 Updater: firmware upgraded to version 02_05_08
4/24/20 17:37:38 Updater: Firmware updated, restarting.
4/24/20 21:37:47z Real Time Clock is running. Unix time 1587764267
4/24/20 21:37:47z Reset reason: Software/System restart
4/24/20 21:37:47z Trace: 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19], 1:6, 1:1[8], 1:2[9], 9:0[9], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:7
4/24/20 21:37:47z ESP8266 ChipID: 6920547
4/24/20 21:37:47z IoTaWatt 4.x, Firmware version 02_05_08
4/24/20 21:37:47z Updater: Installing update files for version 02_05_08
4/24/20 21:37:47z Updater: Installing GRAPH.HTM
4/24/20 21:37:47z Updater: Installing GRAPH.JS
4/24/20 21:37:47z Updater: Installing GRAPH2.HTM
4/24/20 21:37:47z Updater: Installing GRAPH2.JS
4/24/20 21:37:48z Updater: Installing INDEX.HTM
4/24/20 21:37:49z Updater: Installing TABLES.TXT
4/24/20 21:37:49z Updater: Installing CNFSTYLE.CSS
4/24/20 21:37:49z Updater: Installing EDIT.HTM
4/24/20 21:37:49z Updater: Installation complete.
4/24/20 21:37:49z SPIFFS mounted.
4/24/20 17:37:50 Local time zone: -5:00
4/24/20 17:37:50 Using Daylight Saving Time (BST) when in effect.
4/24/20 17:37:50 device name: IotaWaMP
4/24/20 17:37:50 HTTP server started
4/24/20 17:37:50 timeSync: service started.
4/24/20 17:37:50 statService: started.
4/24/20 17:37:50 dataLog: service started.
4/24/20 17:37:51 dataLog: Last log entry 04/24/20 17:37:20
4/24/20 17:37:51 historyLog: service started.
4/24/20 17:37:52 historyLog: Last log entry 04/24/20 17:37:00
4/24/20 17:37:55 influxDB: started, url=HTTP://192.168.1.100:8086, db=IoTaWatt, interval=10
4/24/20 17:37:57 WiFi connected. SSID=PrivetDrive, IP=192.168.1.125, channel=6, RSSI -59db
4/24/20 17:37:57 MDNS responder started for hostname IotaWaMP
4/24/20 17:37:57 LLMNR responder started for hostname IotaWaMP
4/24/20 17:37:57 Updater: service started. Auto-update class is MINOR
4/24/20 17:37:58 Updater: Auto-update is current for class MINOR.
4/24/20 17:37:59 influxDB: Start posting at 04/24/20 17:37:20
4/26/20 10:42:08 Updater: Unrecognized auto-update class MINOR.
4/26/20 11:42:14 Updater: Unrecognized auto-update class MINOR.
4/26/20 12:42:20 Updater: Unrecognized auto-update class MINOR.
4/26/20 13:42:26 Updater: Unrecognized auto-update class MINOR.
4/26/20 14:42:32 Updater: Unrecognized auto-update class MINOR.
4/26/20 15:42:38 Updater: Unrecognized auto-update class MINOR.
4/26/20 16:42:44 Updater: Unrecognized auto-update class MINOR.
4/26/20 17:42:50 Updater: Unrecognized auto-update class MINOR.
4/26/20 18:42:56 Updater: Unrecognized auto-update class MINOR.
4/26/20 19:43:02 Updater: Unrecognized auto-update class MINOR.
4/26/20 20:43:08 Updater: Unrecognized auto-update class MINOR.
4/26/20 21:43:14 Updater: Unrecognized auto-update class MINOR.
4/26/20 22:43:20 Updater: Unrecognized auto-update class MINOR.
4/26/20 23:43:26 Updater: Unrecognized auto-update class MINOR.
4/27/20 00:43:32 Updater: Unrecognized auto-update class MINOR.
4/27/20 01:43:38 Updater: Unrecognized auto-update class MINOR.
4/27/20 02:43:44 Updater: Unrecognized auto-update class MINOR.
4/27/20 03:43:50 Updater: Unrecognized auto-update class MINOR.
4/27/20 04:43:56 Updater: Unrecognized auto-update class MINOR.
4/27/20 05:44:02 Updater: Unrecognized auto-update class MINOR.
4/27/20 06:44:08 Updater: Unrecognized auto-update class MINOR.
4/27/20 07:44:14 Updater: Unrecognized auto-update class MINOR.
4/27/20 08:44:20 Updater: Unrecognized auto-update class MINOR.
4/27/20 09:44:26 Updater: Unrecognized auto-update class MINOR.
4/27/20 10:44:32 Updater: Unrecognized auto-update class MINOR.
4/27/20 11:44:38 Updater: Unrecognized auto-update class MINOR.
4/27/20 12:44:44 Updater: Unrecognized auto-update class MINOR.
4/27/20 13:44:50 Updater: Unrecognized auto-update class MINOR.
4/27/20 14:44:56 Updater: Unrecognized auto-update class MINOR.
4/27/20 15:45:02 Updater: Unrecognized auto-update class MINOR.
4/27/20 16:45:08 Updater: Unrecognized auto-update class MINOR.
4/27/20 17:45:14 Updater: Unrecognized auto-update class MINOR.
4/27/20 18:45:20 Updater: Unrecognized auto-update class MINOR.
4/27/20 19:45:26 Updater: Unrecognized auto-update class MINOR.
4/27/20 20:45:32 Updater: Unrecognized auto-update class MINOR.
4/27/20 21:45:38 Updater: Unrecognized auto-update class MINOR.
4/27/20 22:45:44 Updater: Unrecognized auto-update class MINOR.
4/27/20 23:45:50 Updater: Unrecognized auto-update class MINOR.
4/28/20 00:45:56 Updater: Unrecognized auto-update class MINOR.
4/28/20 01:46:02 Updater: Unrecognized auto-update class MINOR.
4/28/20 02:46:08 Updater: Unrecognized auto-update class MINOR.
4/28/20 03:46:14 Updater: Unrecognized auto-update class MINOR.
4/28/20 04:46:20 Updater: Unrecognized auto-update class MINOR.
4/28/20 05:46:26 Updater: Unrecognized auto-update class MINOR.
4/28/20 06:46:32 Updater: Unrecognized auto-update class MINOR.
4/28/20 07:46:38 Updater: Unrecognized auto-update class MINOR.
4/28/20 08:46:44 Updater: Unrecognized auto-update class MINOR.
4/28/20 09:46:50 Updater: Unrecognized auto-update class MINOR.
4/28/20 10:46:56 Updater: Unrecognized auto-update class MINOR.
I’m aware of this condition. What it’s telling you is that when the IoTaWatt asks iotawatt.com for the current releases corresponding to the various auto-update classes, there is no response for auto-update class MINOR.
I deliberately removed that as part of my diagnostic undertaking on this problem IotaWatt keeps rebooting -- stopped sending data to EmonCMS and PVOutput.
I will add the MINOR entry back in when a new release is available, in the meantime, the message is harmless.
Thanks for the update.
