OK, got logs from one of my devices and it in a loop trying to update to 02_05_08.
Ive changed autoupdate class to Major
4/25/20 09:03:51z ESP8266 ChipID: 2528619
4/25/20 09:03:51z IoTaWatt 5.0, Firmware version 02_05_07
4/25/20 09:03:51z SPIFFS mounted.
4/25/20 09:03:51z Local time zone: +0:00
4/25/20 09:03:51z device name: IotaWatP
4/25/20 09:03:51z HTTP server started
4/25/20 09:03:52z timeSync: service started.
4/25/20 09:03:52z statService: started.
4/25/20 09:03:52z dataLog: service started.
4/25/20 09:03:53z dataLog: Last log entry 04/25/20 09:03:20
4/25/20 09:03:53z historyLog: service started.
4/25/20 09:03:53z historyLog: Last log entry 04/25/20 09:03:00
4/25/20 09:03:57z influxDB: started, url=HTTP://192.168.1.15:8086, db=iotawattdb, interval=10
4/25/20 09:04:12z WiFi connected. SSID=Alkemy, IP=192.168.1.139, channel=1, RSSI -86db
4/25/20 09:04:12z MDNS responder started for hostname IotaWatP
4/25/20 09:04:12z LLMNR responder started for hostname IotaWatP
4/25/20 09:04:12z Updater: service started. Auto-update class is MINOR
4/25/20 09:04:13z influxDB: Start posting at 04/25/20 05:41:20
4/25/20 09:04:15z Updater: Update from 02_05_07 to 02_05_08
4/25/20 09:04:15z Updater: download 02_05_08
4/25/20 09:04:45z dataLog: datalog WDT - restarting
4/25/20 09:04:45z Real Time Clock is running. Unix time 1587805485
4/25/20 09:04:45z Reset reason: Software/System restart
4/25/20 09:04:45z Trace: 1:1[6], 1:2[14], 9:0[14], 9:0, 8:4, 8:2[14], 8:2[14], 1:2, 1:3, 1:4, 1:5[7], 7:0, 7:7, 7:7, 7:7, 1:6, 1:1[14], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:6, 21:100[5], 21:101
4/25/20 09:04:45z ESP8266 ChipID: 2528619
4/25/20 09:04:45z IoTaWatt 5.0, Firmware version 02_05_07
4/25/20 09:04:45z SPIFFS mounted.
4/25/20 09:04:45z Local time zone: +0:00
4/25/20 09:04:45z device name: IotaWatP
4/25/20 09:04:45z HTTP server started
4/25/20 09:04:46z timeSync: service started.
4/25/20 09:04:46z statService: started.
4/25/20 09:04:46z dataLog: service started.
4/25/20 09:04:47z dataLog: Last log entry 04/25/20 09:04:15
4/25/20 09:04:47z historyLog: service started.
4/25/20 09:04:47z historyLog: Last log entry 04/25/20 09:04:00
4/25/20 09:04:50z influxDB: started, url=HTTP://192.168.1.15:8086, db=iotawattdb, interval=10
4/25/20 09:04:59z WiFi connected. SSID=Alkemy, IP=192.168.1.139, channel=13, RSSI -89db
4/25/20 09:04:59z MDNS responder started for hostname IotaWatP
4/25/20 09:04:59z LLMNR responder started for hostname IotaWatP
4/25/20 09:04:59z Updater: service started. Auto-update class is MINOR
4/25/20 09:05:01z Updater: Update from 02_05_07 to 02_05_08
4/25/20 09:05:01z Updater: download 02_05_08
4/25/20 09:05:29z dataLog: datalog WDT - restarting
4/25/20 09:05:31z Real Time Clock is running. Unix time 1587805531
4/25/20 09:05:31z Reset reason: Software/System restart
4/25/20 09:05:31z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[7], 7:0, 7:5, 1:6, 1:1[3], 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:6, 21:100[5], 21:101, 21:101[1]
4/25/20 09:05:31z ESP8266 ChipID: 2528619
4/25/20 09:05:31z IoTaWatt 5.0, Firmware version 02_05_07
4/25/20 09:05:31z SPIFFS mounted.
4/25/20 09:05:31z Local time zone: +0:00
4/25/20 09:05:31z device name: IotaWatP
4/25/20 09:05:31z HTTP server started
4/25/20 09:05:32z timeSync: service started.
4/25/20 09:05:32z statService: started.
4/25/20 09:05:32z dataLog: service started.
4/25/20 09:05:33z dataLog: Last log entry 04/25/20 09:05:00
4/25/20 09:05:33z historyLog: service started.
4/25/20 09:05:33z historyLog: Last log entry 04/25/20 09:05:00
4/25/20 09:05:36z influxDB: started, url=HTTP://192.168.1.15:8086, db=iotawattdb, interval=10
4/25/20 09:05:42z WiFi connected. SSID=Alkemy, IP=192.168.1.139, channel=13, RSSI -91db
4/25/20 09:05:42z MDNS responder started for hostname IotaWatP
4/25/20 09:05:42z LLMNR responder started for hostname IotaWatP
4/25/20 09:05:42z Updater: service started. Auto-update class is MINOR
4/25/20 09:05:43z influxDB: Start posting at 04/25/20 05:44:30
4/25/20 09:05:44z Updater: Update from 02_05_07 to 02_05_08
4/25/20 09:05:44z Updater: download 02_05_08
4/25/20 09:06:10z dataLog: datalog WDT - restarting
4/25/20 09:06:10z Real Time Clock is running. Unix time 1587805570
4/25/20 09:06:10z Reset reason: Software/System restart
4/25/20 09:06:10z Trace: 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[7], 7:0, 7:7, 7:7, 7:7, 1:6, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:6, 21:100[5], 21:101
4/25/20 09:06:10z ESP8266 ChipID: 2528619
4/25/20 09:06:10z IoTaWatt 5.0, Firmware version 02_05_07
4/25/20 09:06:10z SPIFFS mounted.
4/25/20 09:06:10z Local time zone: +0:00
4/25/20 09:06:10z device name: IotaWatP
4/25/20 09:06:10z HTTP server started
4/25/20 09:06:11z timeSync: service started.
4/25/20 09:06:11z statService: started.
4/25/20 09:06:11z dataLog: service started.
4/25/20 09:06:12z dataLog: Last log entry 04/25/20 09:05:40
4/25/20 09:06:12z historyLog: service started.
4/25/20 09:06:12z historyLog: Last log entry 04/25/20 09:05:00
4/25/20 09:06:15z influxDB: started, url=HTTP://192.168.1.15:8086, db=iotawattdb, interval=10
4/25/20 09:06:32z WiFi connected. SSID=Alkemy, IP=192.168.1.139, channel=13, RSSI -90db
4/25/20 09:06:32z MDNS responder started for hostname IotaWatP
4/25/20 09:06:32z LLMNR responder started for hostname IotaWatP
4/25/20 09:06:32z Updater: service started. Auto-update class is MINOR
4/25/20 09:06:33z influxDB: Start posting at 04/25/20 05:44:30
4/25/20 09:06:34z Updater: Update from 02_05_07 to 02_05_08
4/25/20 09:06:34z Updater: download 02_05_08
4/25/20 09:07:00z dataLog: datalog WDT - restarting
4/25/20 09:07:01z Real Time Clock is running. Unix time 1587805621
4/25/20 09:07:01z Reset reason: Software/System restart
4/25/20 09:07:01z Trace: 1:3, 1:4, 1:5[7], 7:0, 7:7, 7:7, 7:7, 7:7, 7:71, 7:71, 7:71, 7:71, 7:71, 7:7, 7:7, 1:6, 1:1[14], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:6, 21:100[5], 21:101
4/25/20 09:07:01z ESP8266 ChipID: 2528619
4/25/20 09:07:01z IoTaWatt 5.0, Firmware version 02_05_07
4/25/20 09:07:01z SPIFFS mounted.
4/25/20 09:07:01z Local time zone: +0:00
4/25/20 09:07:01z device name: IotaWatP
4/25/20 09:07:01z HTTP server started
4/25/20 09:07:02z timeSync: service started.
4/25/20 09:07:02z statService: started.
4/25/20 09:07:02z dataLog: service started.
4/25/20 09:07:03z dataLog: Last log entry 04/25/20 09:06:30
4/25/20 09:07:03z historyLog: service started.
4/25/20 09:07:04z historyLog: Last log entry 04/25/20 09:06:00
4/25/20 09:07:07z influxDB: started, url=HTTP://192.168.1.15:8086, db=iotawattdb, interval=10
4/25/20 09:07:22z WiFi connected. SSID=Alkemy, IP=192.168.1.139, channel=13, RSSI -88db
4/25/20 09:07:22z MDNS responder started for hostname IotaWatP
4/25/20 09:07:22z LLMNR responder started for hostname IotaWatP
4/25/20 09:07:22z Updater: service started. Auto-update class is MINOR
4/25/20 09:07:25z Updater: Update from 02_05_07 to 02_05_08
4/25/20 09:07:25z Updater: download 02_05_08
4/25/20 09:07:55z dataLog: datalog WDT - restarting
4/25/20 09:07:55z Real Time Clock is running. Unix time 1587805675
4/25/20 09:07:55z Reset reason: Software/System restart
4/25/20 09:07:55z Trace: 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:13, 15:0[32], 15:1[32], 15:2[32], 15:3[32], 15:10, 15:12, 15:13, 15:14[32], 15:15[2], 15:16, 15:17, 15:4, 1:4, 1:5[5], 5:0, 5:6, 21:100[5], 21:101, 21:101[1]
4/25/20 09:07:55z ESP8266 ChipID: 2528619
4/25/20 09:07:55z IoTaWatt 5.0, Firmware version 02_05_07
4/25/20 09:07:55z SPIFFS mounted.
4/25/20 09:07:55z Local time zone: +0:00
4/25/20 09:07:55z device name: IotaWatP
4/25/20 09:07:55z HTTP server started
4/25/20 09:07:56z timeSync: service started.
4/25/20 09:07:56z statService: started.
4/25/20 09:07:56z dataLog: service started.
4/25/20 09:07:57z dataLog: Last log entry 04/25/20 09:07:25
4/25/20 09:07:57z historyLog: service started.
4/25/20 09:07:57z historyLog: Last log entry 04/25/20 09:07:00
4/25/20 09:08:01z influxDB: started, url=HTTP://192.168.1.15:8086, db=iotawattdb, interval=10
4/25/20 09:08:15z WiFi connected. SSID=Alkemy, IP=192.168.1.139, channel=1, RSSI -87db
4/25/20 09:08:15z MDNS responder started for hostname IotaWatP
4/25/20 09:08:15z LLMNR responder started for hostname IotaWatP
4/25/20 09:08:15z Updater: service started. Auto-update class is MINOR
4/25/20 09:08:17z Updater: Update from 02_05_07 to 02_05_08
4/25/20 09:08:17z Updater: download 02_05_08
4/25/20 09:08:17z influxDB: Start posting at 04/25/20 05:44:30
4/25/20 09:08:45z dataLog: datalog WDT - restarting
4/25/20 09:08:46z Real Time Clock is running. Unix time 1587805726
4/25/20 09:08:46z Reset reason: Software/System restart
4/25/20 09:08:46z Trace: 9:9, 1:2, 1:3, 1:4, 1:5[7], 7:0, 7:5, 21:110, 21:110, 21:110, 7:5, 1:6, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:6, 21:100[5], 21:101
4/25/20 09:08:46z ESP8266 ChipID: 2528619
4/25/20 09:08:46z IoTaWatt 5.0, Firmware version 02_05_07
4/25/20 09:08:46z SPIFFS mounted.
4/25/20 09:08:46z Local time zone: +0:00
4/25/20 09:08:46z device name: IotaWatP
4/25/20 09:08:46z HTTP server started
4/25/20 09:08:47z timeSync: service started.
4/25/20 09:08:47z statService: started.
4/25/20 09:08:47z dataLog: service started.
4/25/20 09:08:48z dataLog: Last log entry 04/25/20 09:08:15
4/25/20 09:08:48z historyLog: service started.
4/25/20 09:08:48z historyLog: Last log entry 04/25/20 09:08:00
4/25/20 09:08:51z influxDB: started, url=HTTP://192.168.1.15:8086, db=iotawattdb, interval=10
