Head of products from InfluxData here.
I’d like to provide some clarity to a number of points made in this thread.
- InfluxDB Cloud – currently supports the 1.x AND 2.x APIs. This was introduced in July 2020.
- InfluxDB OSS 2.0 is now winding down the beta program and entering into the release candidate phase which leads to general availability. The first release candidate will re-introduce the 1.x APIs for compatibility and should be available next week at the earliest. Yes, it has taken awhile to reach this point. Planned GA is during Q4 – likely early November.
- InfluxDB 2.0 – all editions: Cloud/OSS – are secure by default. Meaning, they all require HTTPS for API access and they all use a username/token combination for API calls. This is a big change from 1.x but one that has been demanded by a large portion of our community.
- Given the ESP8266 does not have adequate memory or appropriate tools for HTTPS, there is already a pre-built proxy that you can use to overcome this. Telegraf is a lightweight OSS-based agent which is used to gather a wide variety of metrics/logs/etc. If you want to leverage the new editions of InfluxDB you can do this with ZERO code changes to IoTaWatt.
Following the pattern above:
IoTaWatt → influxDB_listener input /[ Telegraf /] influxDBv2_output → InfluxDB 2.0 (OSS or Cloud)
You can then use the native UI to build beautiful dashboards.
If you already have dashboards built, in say Grafana, you can use the influxDBv1_output and this will create the appropriate mappings and land the data precisely as it was in InfluxDB 1.x. You can then continue to leverage your Grafana dashboards by creating an InfluxDB data source connection leveraging the InfluxQL language in Grafana 7.1.x or above. The instructions are here.
You can send the HTTP-based metrics to the influxDB_listener input plugin configured within Telegraf. This essentially makes Telegraf look like an InfluxDB 1.x instance. Telegraf can then be configured with the appropriate security credentials and will translate the inbound payload to what InfluxDB 2.0 expects (via the InfluxDB 2.0 output plugin) using HTTPS (or use InfluxDB v1.x output plugin and the appropriate compatibility APIs will be leveraged).
Further, if you have an existing setup with InfluxDB and you want to dual write — simply to explore the capabilities of InfluxDB 2.0, you can do this with Telegraf as well. Telegraf is capable of having multiple output plugins configured. Meaning you can configure 1 output plugin for your existing 1.x instance while configuring a 2nd output plugin for InfluxDB 2.0 (again, either Cloud or OSS).
We have a very large community of open source projects and applications that have leveraged the capabilities of InfluxDB and we appreciate the support, interest, contributions, and effort that is has taken to grow such a community. We did not want to aggressively deliver a major upgrade to the OSS community without thought, consideration and feedback from our developers who have clearly put their trust into our technology. So, we have been very deliberate about not pushing the OSS edition towards GA haphazardly. All of the new capabilities have been tested in the Cloud edition first and we continue to deliver improvements, feature additions and more approximately 25-30x/week to the Cloud edition. We’ve now been effectively running the Cloud edition at scale for a year and are confident that we are ready to move the OSS edition forward to a GA state starting with Linux packages and then expanding towards Windows and other platforms.
We’ve reached this point by listening to feedback and incorporating these kinds of compatibility modes and techniques in an effort to minimize code changes as much as possible while also trying to move such a large community forward.
Happy to field additional questions or if you would like to dig deeper, we welcome your inputs to our community site as well → community . influxdata . com
Thank you…
