Big Changes to ESP32 effort
This would be neat, especially in combination with these tiny CTs but it sounds to me that the space constraints would require some serious adaptations compared to the usual non-DIN variant. For one, using the TRS jacks is most likely going to be space prohibitive in that sort of application. Not to mention that if you’re looking at a DIN rail already, a stripped wire is going to be more convenient to work with anyhow. From there you probably wouldn’t use an ESP32 board as a daughterboard of sorts, but rather solder the bare chip to the motherboard. All things considered this would require some pretty different PCB layouts and make production of the PCBs quite a bit more complex (the ESP32s are all BGA packages AFAIK.) So all in all, it most likely would end up being a separate effort, I imagine.
(As a side note, I wouldn’t mind plain terminals and stripped wire for CT connections even for the non-DIN version. I think that would allow for a much more compact IoTaWatt in general and it permits a wider choice of CTs, given how much faster it is to cut and strip wire on whatever connector might be in place than it is to attach a TRS plug to a wire without one)
