I have had my Iottawatt installed and working since August 2022 (Order #127107). Two weeks ago it stopped reporting, and the web interface was unreachable. I have not changed the configuration in months, and the last time it had been power cycled was also likely months ago as well during a power outage.
It has been blinking green, about once a second. My router claims that is it connected on it’s static IP; but the device does not respond on HTTP or pings. I also have tried manually power cycling it; no change.
I have found this other post that seems to be the same problem. I followed the advice posted there to restore the files on the SD card; tried both on the original SD card as well as a new SD card formatted to fat32. This still causes the same flashing green rapid-reset.
Both before, and after the sd-card resets these are the messages in the iotamsgs.txt file.
iotamsgs.txt (22.7 KB)
10/20/23 18:22:13z Real Time Clock is running. Unix time 1697826133
10/20/23 18:22:13z Reset reason: Exception
10/20/23 18:22:13z Trace: 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 11:0, 11:4, 11:5, 11:5, 11:10, 11:15, 11:20, 11:20[1], 11:20[2], 11:20[3], 11:21, 11:22, 11:20[4], 11:20[5], 11:20[6], 11:20[7], 11:25
10/20/23 18:22:13z ESP8266 ID: 15885208, RTC PCF8523 (68)
10/20/23 18:22:13z IoTaWatt 5.0, Firmware version 02_08_02
10/20/23 18:22:13z SPIFFS mounted.
