3/20/22 13:09:09 timeSync: service started.
3/20/22 13:09:22 statService: started.
3/20/22 13:09:22 Updater: service started. Auto-update class is MINOR
3/20/22 13:09:22 dataLog: service started.
3/20/22 13:09:22 dataLog: Last log entry 03/20/22 13:08:55
3/20/22 13:09:23 historyLog: service started.
3/20/22 13:09:23 historyLog: Last log entry 03/20/22 13:08:00
3/20/22 13:09:36 emoncms: Query failed -4
3/20/22 13:09:36 emoncms: stopped, Last post 02/05/06 22:28:16
3/20/22 13:09:51 Updater: Invalid response from server. HTTPcode: -4
3/20/22 20:10:04z Real Time Clock is running. Unix time 1647807004
3/20/22 20:10:04z Reset Reason: Power-fail restart.
3/20/22 20:10:04z ESP8266 ID: 567229, RTC M41T81 (68)
3/20/22 20:10:04z IoTaWatt 5.0, Firmware version 02_07_05
3/20/22 20:10:04z SPIFFS mounted.
3/20/22 13:10:04 Local time zone: -8:00, using DST/BST when in effect.
3/20/22 13:10:04 device name: IotaWatt
3/20/22 13:10:07 Connecting with WiFiManager.
3/20/22 13:10:12 HTTP server started
3/20/22 13:10:12 emoncms: Starting, interval:10, url:http://emoncms.org
3/20/22 13:10:12 WiFi connected. SSID=Safelink_9098, IP=192.168.11.134, channel=11, RSSI -73db
3/20/22 13:10:12 MDNS responder started for hostname IotaWatt
3/20/22 13:10:12 LLMNR responder started for hostname IotaWatt
3/20/22 13:10:12 timeSync: service started.
3/20/22 20:10:52z Real Time Clock is running. Unix time 1647807052
3/20/22 20:10:52z Reset Reason: Power-fail restart.
3/20/22 20:10:52z ESP8266 ID: 567229, RTC M41T81 (68)
3/20/22 20:10:52z IoTaWatt 5.0, Firmware version 02_07_05
3/20/22 20:10:52z SPIFFS mounted.
3/20/22 13:10:52 Local time zone: -8:00, using DST/BST when in effect.
3/20/22 13:10:52 device name: IotaWatt
3/20/22 13:10:55 Connecting with WiFiManager.
3/20/22 13:11:00 HTTP server started
3/20/22 13:11:00 emoncms: Starting, interval:10, url:http://emoncms.org
3/20/22 13:11:00 WiFi connected. SSID=Safelink_9098, IP=192.168.11.134, channel=11, RSSI -71db
3/20/22 13:11:00 MDNS responder started for hostname IotaWatt
3/20/22 13:11:00 LLMNR responder started for hostname IotaWatt
3/20/22 13:11:00 timeSync: service started.
3/20/22 13:11:13 statService: started.
3/20/22 13:11:13 Updater: service started. Auto-update class is MINOR
3/20/22 13:11:13 dataLog: service started.
3/20/22 13:11:14 dataLog: Last log entry 03/20/22 13:09:55
3/20/22 13:11:14 historyLog: service started.
3/20/22 13:11:14 historyLog: Last log entry 03/20/22 13:09:00
3/20/22 13:11:28 emoncms: Query failed -4
3/20/22 13:11:28 emoncms: stopped, Last post 02/05/06 22:28:16
3/20/22 13:11:43 Updater: Invalid response from server. HTTPcode: -4
3/20/22 20:12:08z Real Time Clock is running. Unix time 1647807128
3/20/22 20:12:08z Reset Reason: Power-fail restart.
3/20/22 20:12:08z ESP8266 ID: 567229, RTC M41T81 (68)
3/20/22 20:12:08z IoTaWatt 5.0, Firmware version 02_07_05
3/20/22 20:12:08z SPIFFS mounted.
3/20/22 13:12:08 Local time zone: -8:00, using DST/BST when in effect.
3/20/22 13:12:08 device name: IotaWatt
3/20/22 13:12:11 Connecting with WiFiManager.
3/20/22 13:12:16 HTTP server started
3/20/22 13:12:16 emoncms: Starting, interval:10, url:http://emoncms.org
3/20/22 13:12:16 WiFi connected. SSID=Safelink_9098, IP=192.168.11.134, channel=11, RSSI -72db
3/20/22 13:12:16 MDNS responder started for hostname IotaWatt
3/20/22 13:12:16 LLMNR responder started for hostname IotaWatt
3/20/22 13:12:16 timeSync: service started.
3/20/22 13:12:29 statService: started.
3/20/22 13:12:29 Updater: service started. Auto-update class is MINOR
3/20/22 13:12:29 dataLog: service started.
3/20/22 13:12:29 dataLog: Last log entry 03/20/22 13:11:45
3/20/22 13:12:30 historyLog: service started.
3/20/22 13:12:30 historyLog: Last log entry 03/20/22 13:11:00
3/20/22 13:12:44 emoncms: Query failed -4
3/20/22 13:12:44 emoncms: stopped, Last post 02/05/06 22:28:16
3/20/22 13:12:59 Updater: Invalid response from server. HTTPcode: -4
3/20/22 14:12:36 Updater: Auto-update is current for class MINOR.
3/21/22 04:18:35 Solar: Started
3/21/22 04:18:35 Solar: New log starting 03/20/22 04:18:35
3/21/22 04:48:47 Solar: Integration log Solar deleted.
3/21/22 04:48:47 Script: integration Solar not defined in script Solar.
3/21/22 04:50:12 Script: integration Solar not defined in script Solar.
3/21/22 04:50:12 Solar_Total: Started
3/21/22 04:50:12 Solar_Total: New log starting 03/20/22 04:50:10
3/21/22 04:55:03 Script: integration Solar not defined in script Solar.
3/21/22 04:55:12 Script: integration Solar not defined in script Solar.
3/21/22 04:55:41 Script: integration Solar not defined in script Solar.
3/21/22 04:56:01 Script: integration Solar not defined in script Solar.
3/21/22 04:56:39 Script: integration Solar not defined in script Solar.
3/21/22 05:12:20 deletelog=both command received.
3/21/22 12:12:23z Real Time Clock is running. Unix time 1647864743
3/21/22 12:12:23z Reset reason: Software/System restart
3/21/22 12:12:23z Trace: 1:1[4], 1:2[11], 9:0[11], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[11], 1:2[12], 9:0[12], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:21, 10:23
3/21/22 12:12:23z ESP8266 ID: 567229, RTC M41T81 (68)
3/21/22 12:12:23z IoTaWatt 5.0, Firmware version 02_07_05
3/21/22 12:12:23z SPIFFS mounted.
3/21/22 05:12:23 Local time zone: -8:00, using DST/BST when in effect.
3/21/22 05:12:23 device name: IotaWatt
3/21/22 05:12:23 HTTP server started
3/21/22 05:12:23 emoncms: Starting, interval:10, url:http://emoncms.org
3/21/22 05:12:23 timeSync: service started.
3/21/22 05:12:23 statService: started.
3/21/22 05:12:23 dataLog: service started.
3/21/22 05:12:23 dataLog: New current log created.
3/21/22 05:12:28 Solar_Total: Started
3/21/22 05:12:28 Solar_Total: Last log entry 03/21/22 05:12:20
3/21/22 05:12:29 WiFi connected. SSID=Safelink_9098, IP=192.168.11.134, channel=11, RSSI -71db
3/21/22 05:12:29 MDNS responder started for hostname IotaWatt
3/21/22 05:12:29 LLMNR responder started for hostname IotaWatt
3/21/22 05:12:29 Updater: service started. Auto-update class is MINOR
3/21/22 05:12:29 emoncms: Start posting at 03/21/22 05:12:30
3/21/22 05:12:29 emoncms: stopped, Last post 03/21/22 05:12:20
3/21/22 05:12:31 Updater: Auto-update is current for class MINOR.
3/21/22 05:13:28 historyLog: service started.
3/21/22 05:13:28 historyLog: first entry 03/21/22 05:13:00
3/21/22 05:15:41 Restart command received.
3/21/22 12:15:43z Real Time Clock is running. Unix time 1647864943
3/21/22 12:15:43z Reset reason: Software/System restart
3/21/22 12:15:43z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[4], 1:2[11], 9:0[11], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
3/21/22 12:15:43z ESP8266 ID: 567229, RTC M41T81 (68)
3/21/22 12:15:43z IoTaWatt 5.0, Firmware version 02_07_05
3/21/22 12:15:43z SPIFFS mounted.
3/21/22 05:15:43 Local time zone: -8:00, using DST/BST when in effect.
3/21/22 05:15:43 device name: IotaWatt
3/21/22 05:15:43 HTTP server started
3/21/22 05:15:43 emoncms: Starting, interval:10, url:http://emoncms.org
3/21/22 05:15:43 timeSync: service started.
3/21/22 05:15:43 statService: started.
3/21/22 05:15:43 dataLog: service started.
3/21/22 05:15:43 dataLog: Last log entry 03/21/22 05:15:40
3/21/22 05:15:47 WiFi connected. SSID=Safelink_9098, IP=192.168.11.134, channel=11, RSSI -75db
3/21/22 05:15:47 MDNS responder started for hostname IotaWatt
3/21/22 05:15:47 LLMNR responder started for hostname IotaWatt
3/21/22 05:15:47 Updater: service started. Auto-update class is MINOR
3/21/22 05:15:47 emoncms: Start posting at 03/21/22 05:12:30
3/21/22 05:15:47 emoncms: stopped, Last post 03/21/22 05:12:20
3/21/22 05:15:48 historyLog: service started.
3/21/22 05:15:48 historyLog: Last log entry 03/21/22 05:15:00
3/21/22 05:15:48 Solar_Total: Started
3/21/22 05:15:48 Solar_Total: Last log entry 03/21/22 05:15:40
3/21/22 05:15:50 Updater: Auto-update is current for class MINOR.
3/21/22 05:27:29 Solar_Total: Integration log Solar_Total deleted.
3/21/22 05:27:29 Script: integration Solar_Total not defined in script Solar.
3/21/22 05:43:54 Restart command received.
3/21/22 12:43:56z Real Time Clock is running. Unix time 1647866636
3/21/22 12:43:56z Reset reason: Software/System restart
3/21/22 12:43:56z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[13], 1:2[14], 9:0[14], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[14], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 10:2, 10:3
3/21/22 12:43:56z ESP8266 ID: 567229, RTC M41T81 (68)
3/21/22 12:43:56z IoTaWatt 5.0, Firmware version 02_07_05
3/21/22 12:43:56z SPIFFS mounted.
3/21/22 05:43:56 Local time zone: -8:00, using DST/BST when in effect.
3/21/22 05:43:56 device name: IotaWatt
3/21/22 05:43:56 HTTP server started
3/21/22 05:43:56 emoncms: Starting, interval:10, url:http://emoncms.org
3/21/22 05:43:56 timeSync: service started.
3/21/22 05:43:56 statService: started.
3/21/22 05:43:56 dataLog: service started.
3/21/22 05:43:56 dataLog: Last log entry 03/21/22 05:43:50
3/21/22 05:44:01 historyLog: service started.
3/21/22 05:44:01 historyLog: Last log entry 03/21/22 05:43:00
3/21/22 05:44:02 WiFi connected. SSID=Safelink_9098, IP=192.168.11.134, channel=11, RSSI -72db
3/21/22 05:44:02 MDNS responder started for hostname IotaWatt
3/21/22 05:44:02 LLMNR responder started for hostname IotaWatt
3/21/22 05:44:02 Updater: service started. Auto-update class is MINOR
3/21/22 05:44:02 emoncms: Start posting at 03/21/22 05:12:30
3/21/22 05:44:02 emoncms: stopped, Last post 03/21/22 05:12:20
3/21/22 05:44:05 Updater: Auto-update is current for class MINOR.
