I did restart the browser. And did a Ctl-F5.
Here’s the log. The 401 errors are my fault - I first uploaded the exact file I sent you above - with the API key 'x’d out! Second upload & restart is with the key corrected. It’s been running for the last day, happily uploading to EmonCMS.
7/20/21 18:10:29z Real Time Clock is running. Unix time 1626804629
7/20/21 18:10:29z Reset reason: Software/System restart
7/20/21 18:10:29z Trace: 1:6[6], 1:1[7], 1:2[8], 9:0[8], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[8], 1:2[9], 9:0[9], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
7/20/21 18:10:29z ESP8266 ChipID: 2870702
7/20/21 18:10:29z IoTaWatt 4.x, Firmware version 02_06_05
7/20/21 18:10:29z SPIFFS mounted.
7/20/21 18:10:29z setConfig: config.txt open failed.
7/20/21 18:10:29z config file invalid, attempting recovery.
7/20/21 12:10:30 configuration recovery successful.
7/20/21 12:10:30 Local time zone: -7:00
7/20/21 12:10:30 Using Daylight Saving Time (BST) when in effect.
7/20/21 12:10:30 device name: IotaWatt
7/20/21 12:10:30 HTTP server started
7/20/21 12:10:30 emoncms: Starting, interval:10, url:http://192.168.0.6/emoncms
7/20/21 12:10:30 timeSync: service started.
7/20/21 12:10:30 statService: started.
7/20/21 12:10:31 dataLog: service started.
7/20/21 12:10:31 dataLog: Last log entry 07/20/21 12:10:25
7/20/21 12:10:35 historyLog: service started.
7/20/21 12:10:35 historyLog: Last log entry 07/20/21 12:10:00
7/20/21 12:10:35 WiFi connected. SSID=BLACKBURN, IP=192.168.0.17, channel=11, RSSI -66db
7/20/21 12:10:36 MDNS responder started for hostname IotaWatt
7/20/21 12:10:36 LLMNR responder started for hostname IotaWatt
7/20/21 12:10:36 Updater: service started. Auto-update class is ALPHA
7/20/21 12:10:36 emoncms: Query failed 401
7/20/21 12:10:38 Updater: Auto-update is current for class ALPHA.
7/20/21 12:10:41 emoncms: Query failed 401
7/20/21 12:10:46 emoncms: Query failed 401
7/20/21 12:10:51 emoncms: Query failed 401
7/20/21 12:10:56 emoncms: Query failed 401
7/20/21 12:11:01 emoncms: Query failed 401
7/20/21 12:13:23 Restart command received.
7/20/21 18:13:25z Real Time Clock is running. Unix time 1626804805
7/20/21 18:13:25z Reset reason: Software/System restart
7/20/21 18:13:25z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
7/20/21 18:13:25z ESP8266 ChipID: 2870702
7/20/21 18:13:25z IoTaWatt 4.x, Firmware version 02_06_05
7/20/21 18:13:25z SPIFFS mounted.
7/20/21 18:13:25z setConfig: config.txt open failed.
7/20/21 18:13:25z config file invalid, attempting recovery.
7/20/21 12:13:26 configuration recovery successful.
7/20/21 12:13:26 Local time zone: -7:00
7/20/21 12:13:26 Using Daylight Saving Time (BST) when in effect.
7/20/21 12:13:26 device name: IotaWatt
7/20/21 12:13:26 HTTP server started
7/20/21 12:13:26 emoncms: Starting, interval:10, url:http://192.168.0.6/emoncms
7/20/21 12:13:26 timeSync: service started.
7/20/21 12:13:26 statService: started.
7/20/21 12:13:27 dataLog: service started.
7/20/21 12:13:27 dataLog: Last log entry 07/20/21 12:13:20
7/20/21 12:13:31 historyLog: service started.
7/20/21 12:13:31 historyLog: Last log entry 07/20/21 12:13:00
7/20/21 12:13:31 WiFi connected. SSID=BLACKBURN, IP=192.168.0.17, channel=11, RSSI -68db
7/20/21 12:13:32 MDNS responder started for hostname IotaWatt
7/20/21 12:13:32 LLMNR responder started for hostname IotaWatt
7/20/21 12:13:32 Updater: service started. Auto-update class is ALPHA
7/20/21 12:13:32 emoncms: Start posting at 05/03/21 21:07:30
7/20/21 12:13:34 Updater: Auto-update is current for class ALPHA.
