Good afternoon,
tldr; 2022-06-12: I’m troubleshooting a heap memory issue. The solution isn’t here, yet. Please let me know if something else can be enabled for troubleshooting. I am uploading to influxDB_v2 and hoping to help. This is not urgent.
I’ve come across a new issue and seen it discussed a few times. It’s not urgent, but I wanted to update real-time and will edit here when I have more information. My only intention on posting the amount of details is to help others navigate and hopefully reduce some common questions.
This issue occurred after my recent resolved issue with WiFi connectivity.
Some related topics to my current findings:
- Degraded Heap, Multiple Starts and Confusing Messages
- Problem with Heap degradation restarts
- "Config not found" - ERROR[403]: Protected
What I’ve done so far based on what I could find in other posts:
- I’ve modified my
config.txtvia the ACE Editor. You cannot edit theconfig.txtfile directly through the ACE Editor, by design, to help protect users from errors. (e.g. do not be too confident, the quotes can cause problems) - The file cannot be edited directly followed by a CTRL-S (to save the file). I received an http error code of 403 (permission issues) so additional steps are required.
- Added
"heap": true,to theconfig.txtfile (I followed the instructions by editing a file on my local machine and named itconfig+1.txt, running through a JSON lint tool, and then uploaded and restarted my IoTaWatt so theconfig+1.txtfile receives a syntax check and becomes the newconfig.txt). Personally, I usedjsonlint-phpin Ubuntu (installed viaapt install jsonlint. The command-line tool is calledjsonlint-php).
NOTE: Copy/Paste’ing the"heap": true,from this post into theconfig.txtfile is going to give you the odd quotes and cause an error. Make sure you change them. - Restarted IoTaWatt and confirmed the new
config.txtcontained the"heap": true,setting in the"influxdb2"section.
root@ubuntu:/# jsonlint-php /tmp/config+1.txt
Valid JSON (/tmp/config+1.txt)
root@ubuntu:/#
And this is what my "influxdb2" section looks like in config.txt after restarting with an uploaded config+1.txt file with the added entry for heap (your url entry may be different):
"influxdb2": {
"type": "influxdb2",
"revision": 17,
"heap":true,
"postInterval": 5,
"bulksend": 10,
"url": "http://192.168.10.1:8086",
Here’s my message log:
6/08/22 14:59:41z Real Time Clock is running. Unix time 1654700381
6/08/22 14:59:41z Reset Reason: Power-fail restart.
6/08/22 14:59:41z ESP8266 ID: 482274, RTC M41T81 (68)
6/08/22 14:59:41z IoTaWatt 5.0, Firmware version 02_07_05
6/08/22 14:59:41z SPIFFS mounted.
6/08/22 14:59:41z Local time zone: +0:00
6/08/22 14:59:41z device name: IotaWatt
6/08/22 14:59:44z Connecting with WiFiManager.
6/08/22 15:01:51z HTTP server started
6/08/22 15:01:51z influxDB_v2: Starting, interval:5, url:http://192.168.10.1:8086
6/08/22 15:01:51z WiFi connected. SSID=<redacted>, IP=192.168.10.233, channel=2, RSSI -39db
6/08/22 15:01:51z MDNS responder started for hostname IotaWatt
6/08/22 15:01:51z LLMNR responder started for hostname IotaWatt
6/08/22 15:01:51z timeSync: service started.
6/08/22 15:01:51z statService: started.
6/08/22 15:01:51z Updater: service started. Auto-update class is MINOR
6/08/22 15:01:52z dataLog: service started.
6/08/22 15:01:52z dataLog: Last log entry 06/08/22 14:59:35
6/08/22 15:01:53z influxDB_v2: Resume posting 06/08/22 04:30:40
6/08/22 15:01:54z Updater: Auto-update is current for class MINOR.
6/08/22 15:01:56z historyLog: service started.
6/08/22 15:01:56z historyLog: Last log entry 06/08/22 14:59:00
6/11/22 11:54:47z WiFi disconnected.
6/11/22 11:54:55z WiFi connected. SSID=<redacted>, IP=192.168.10.233, channel=7, RSSI -34db
6/11/22 12:59:06z WiFi disconnected.
6/11/22 12:59:14z WiFi connected. SSID=<redacted>, IP=192.168.10.233, channel=11, RSSI -39db
6/11/22 14:11:59z WiFi disconnected.
6/11/22 14:12:03z WiFi connected. SSID=<redacted>, IP=192.168.10.233, channel=6, RSSI -35db
6/12/22 01:38:49z WiFi disconnected.
6/12/22 01:38:53z WiFi connected. SSID=<redacted>, IP=192.168.10.233, channel=10, RSSI -39db
6/12/22 02:06:07z WiFi disconnected.
6/12/22 02:06:12z WiFi connected. SSID=<redacted>, IP=192.168.10.233, channel=1, RSSI -37db
6/12/22 02:10:22z Updater: Invalid response from server. HTTPcode: -4
6/12/22 02:30:56z WiFi disconnected.
6/12/22 02:31:07z WiFi connected. SSID=<redacted>, IP=192.168.10.233, channel=8, RSSI -44db
6/12/22 04:35:00z Heap memory has degraded below safe minimum, restarting.
6/12/22 04:35:02z Real Time Clock is running. Unix time 1655008502
6/12/22 04:35:02z Reset reason: Software/System restart
6/12/22 04:35:02z Trace: 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:4, 18:5, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
6/12/22 04:35:02z ESP8266 ID: 482274, RTC M41T81 (68)
6/12/22 04:35:02z IoTaWatt 5.0, Firmware version 02_07_05
6/12/22 04:35:02z SPIFFS mounted.
6/12/22 04:35:02z Local time zone: +0:00
6/12/22 04:35:02z device name: IotaWatt
6/12/22 04:35:02z HTTP server started
6/12/22 04:35:02z influxDB_v2: Starting, interval:5, url:http://192.168.10.1:8086
6/12/22 04:35:02z timeSync: service started.
6/12/22 04:35:02z statService: started.
6/12/22 04:35:02z dataLog: service started.
6/12/22 04:35:02z dataLog: Last log entry 06/12/22 04:35:00
6/12/22 04:35:06z WiFi connected. SSID=<redacted>, IP=192.168.10.233, channel=8, RSSI -42db
6/12/22 04:35:06z MDNS responder started for hostname IotaWatt
6/12/22 04:35:06z LLMNR responder started for hostname IotaWatt
6/12/22 04:35:06z Updater: service started. Auto-update class is MINOR
6/12/22 04:35:06z influxDB_v2: Resume posting 06/12/22 04:09:25
6/12/22 04:35:10z historyLog: service started.
6/12/22 04:35:10z historyLog: Last log entry 06/12/22 04:35:00
6/12/22 04:35:30z Updater: Invalid response from server. HTTPcode: -4
6/12/22 05:55:31z WiFi disconnected.
6/12/22 05:55:39z WiFi connected. SSID=<redacted>, IP=192.168.10.233, channel=2, RSSI -37db
6/12/22 07:35:18z Updater: Auto-update is current for class MINOR.
6/12/22 16:08:37 Updater: Auto-update class changed to MAJOR
6/12/22 16:08:38 Updater: Auto-update is current for class MAJOR.
6/12/22 16:08:59 Restart command received.
6/12/22 23:09:00z Real Time Clock is running. Unix time 1655075340
6/12/22 23:09:00z Reset reason: Software/System restart
6/12/22 23:09:00z Trace: 1:3, 1:1[4], 1:2[6], 9:0[6], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[6], 1:2[7], 9:0[7], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
6/12/22 23:09:00z ESP8266 ID: 482274, RTC M41T81 (68)
6/12/22 23:09:00z IoTaWatt 5.0, Firmware version 02_07_05
6/12/22 23:09:00z SPIFFS mounted.
6/12/22 16:09:00 Local time zone: -8:00, using DST/BST when in effect.
6/12/22 16:09:00 device name: IotaWatt
6/12/22 16:09:00 HTTP server started
6/12/22 16:09:00 influxDB_v2: Starting, interval:5, url:http://192.168.10.1:8086
6/12/22 16:09:00 timeSync: service started.
6/12/22 16:09:00 statService: started.
6/12/22 16:09:00 dataLog: service started.
6/12/22 16:09:00 dataLog: Last log entry 06/12/22 16:08:55
6/12/22 16:09:05 historyLog: service started.
6/12/22 16:09:05 historyLog: Last log entry 06/12/22 16:08:00
6/12/22 16:09:05 WiFi connected. SSID=<redacted>, IP=192.168.10.233, channel=2, RSSI -37db
6/12/22 16:09:05 MDNS responder started for hostname IotaWatt
6/12/22 16:09:05 LLMNR responder started for hostname IotaWatt
6/12/22 16:09:05 Updater: service started. Auto-update class is MAJOR
6/12/22 16:09:05 influxDB_v2: Resume posting 06/12/22 16:08:15
6/12/22 16:09:06 Updater: Auto-update is current for class MAJOR.
6/12/22 16:26:40 Restart command received.
6/12/22 23:26:42z Real Time Clock is running. Unix time 1655076402
6/12/22 23:26:42z Reset reason: Software/System restart
6/12/22 23:26:42z Trace: 1:3, 1:3, 1:3, 1:1[13], 1:2[14], 9:0[14], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:3, 1:3, 1:1[14], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 10:2, 10:3
6/12/22 23:26:42z ESP8266 ID: 482274, RTC M41T81 (68)
6/12/22 23:26:42z IoTaWatt 5.0, Firmware version 02_07_05
6/12/22 23:26:42z SPIFFS mounted.
6/12/22 16:26:42 Local time zone: -8:00, using DST/BST when in effect.
6/12/22 16:26:42 device name: IotaWatt
6/12/22 16:26:42 HTTP server started
6/12/22 16:26:42 influxDB_v2: Starting, interval:5, url:http://192.168.10.1:8086
6/12/22 16:26:42 timeSync: service started.
6/12/22 16:26:42 statService: started.
6/12/22 16:26:42 dataLog: service started.
6/12/22 16:26:42 dataLog: Last log entry 06/12/22 16:26:40
6/12/22 16:26:47 historyLog: service started.
6/12/22 16:26:47 historyLog: Last log entry 06/12/22 16:26:00
6/12/22 16:26:47 WiFi connected. SSID=<redacted>, IP=192.168.10.233, channel=2, RSSI -38db
6/12/22 16:26:47 MDNS responder started for hostname IotaWatt
6/12/22 16:26:47 LLMNR responder started for hostname IotaWatt
6/12/22 16:26:47 Updater: service started. Auto-update class is MAJOR
6/12/22 16:26:47 influxDB_v2: Resume posting 06/12/22 16:26:15
6/12/22 16:26:49 Updater: Auto-update is current for class MAJOR.
NOTE: I changed auto-update from MINOR to MAJOR in case a new firmware update was available.
Current heap metrics:
