Thank you for the fast response. What i meant by “regular LAN” was simply my home LAN network accessed from a local device as opposed to a device connecting to my local LAN through my VPN.
It took me about 15 minutes to log into the IoTaWatt so i could pull the logs. After multiple tries, it finally connected and i accessed the logs. My Hubitat did not lose the connection to the IoTaWatt and i was able to see power changes from the IoTaWatt in Hubitat. Very strange behavior. I’m sure I must be doing something wrong.
Here is the logs:
12/27/19 02:20:46 historyLog: service started.
12/27/19 02:20:46 historyLog: Last log entry 12/27/19 02:18:00
12/27/19 07:21:57z Real Time Clock is running. Unix time 1577431317
12/27/19 07:21:57z Reset reason: Exception
12/27/19 07:21:57z Trace: 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6]
12/27/19 07:21:57z ESP8266 ChipID: 6308294
12/27/19 07:21:57z IoTaWatt 5.0, Firmware version 02_05_02
12/27/19 07:21:57z SPIFFS mounted.
12/27/19 02:21:58 Local time zone: -5:00
12/27/19 02:21:58 Using Daylight Saving Time (BST) when in effect.
12/27/19 02:21:58 device name: IotaWatt
12/27/19 02:21:58 MDNS responder started for hostname IotaWatt
12/27/19 02:21:58 LLMNR responder started for hostname IotaWatt
12/27/19 02:21:58 HTTP server started
12/27/19 02:21:58 timeSync: service started.
12/27/19 02:21:58 statService: started.
12/27/19 02:21:58 Updater: service started. Auto-update class is MINOR
12/27/19 02:21:58 dataLog: service started.
12/27/19 02:21:58 dataLog: Last log entry 12/27/19 02:21:55
12/27/19 02:21:59 WiFi connected. SSID=loumarjr, IP=192.168.8.186, channel=11, RSSI -73db
12/27/19 02:22:09 Updater: Auto-update is current for class MINOR.
12/27/19 02:22:58 historyLog: service started.
12/27/19 02:22:58 historyLog: Last log entry 12/27/19 02:21:00
12/27/19 07:24:13z Real Time Clock is running. Unix time 1577431453
12/27/19 07:24:13z Reset reason: Exception
12/27/19 07:24:13z Trace: 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6]
12/27/19 07:24:13z ESP8266 ChipID: 6308294
12/27/19 07:24:13z IoTaWatt 5.0, Firmware version 02_05_02
12/27/19 07:24:13z SPIFFS mounted.
12/27/19 02:24:14 Local time zone: -5:00
12/27/19 02:24:14 Using Daylight Saving Time (BST) when in effect.
12/27/19 02:24:14 device name: IotaWatt
12/27/19 02:24:14 MDNS responder started for hostname IotaWatt
12/27/19 02:24:14 LLMNR responder started for hostname IotaWatt
12/27/19 02:24:14 HTTP server started
12/27/19 02:24:14 timeSync: service started.
12/27/19 02:24:14 statService: started.
12/27/19 02:24:14 Updater: service started. Auto-update class is MINOR
12/27/19 02:24:14 dataLog: service started.
12/27/19 02:24:14 dataLog: Last log entry 12/27/19 02:24:10
12/27/19 02:24:15 WiFi connected. SSID=loumarjr, IP=192.168.8.186, channel=11, RSSI -76db
12/27/19 02:24:15 Updater: Auto-update is current for class MINOR.
12/27/19 02:25:14 historyLog: service started.
12/27/19 02:25:14 historyLog: Last log entry 12/27/19 02:24:00
12/27/19 07:39:06z Real Time Clock is running. Unix time 1577432346
12/27/19 07:39:06z Reset reason: Exception
12/27/19 07:39:06z Trace: 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6]
12/27/19 07:39:06z ESP8266 ChipID: 6308294
12/27/19 07:39:06z IoTaWatt 5.0, Firmware version 02_05_02
12/27/19 07:39:06z SPIFFS mounted.
12/27/19 02:39:07 Local time zone: -5:00
12/27/19 02:39:07 Using Daylight Saving Time (BST) when in effect.
12/27/19 02:39:07 device name: IotaWatt
12/27/19 02:39:07 MDNS responder started for hostname IotaWatt
12/27/19 02:39:07 LLMNR responder started for hostname IotaWatt
12/27/19 02:39:07 HTTP server started
12/27/19 02:39:07 timeSync: service started.
12/27/19 02:39:07 statService: started.
12/27/19 02:39:07 Updater: service started. Auto-update class is MINOR
12/27/19 02:39:07 dataLog: service started.
12/27/19 02:39:07 dataLog: Last log entry 12/27/19 02:39:00
12/27/19 02:39:08 WiFi connected. SSID=loumarjr, IP=192.168.8.186, channel=11, RSSI -74db
12/27/19 02:39:08 Updater: Auto-update is current for class MINOR.
12/27/19 02:40:07 historyLog: service started.
12/27/19 02:40:07 historyLog: Last log entry 12/27/19 02:39:00
12/27/19 07:42:24z Real Time Clock is running. Unix time 1577432544
12/27/19 07:42:24z Reset reason: Exception
12/27/19 07:42:24z Trace: 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6]
12/27/19 07:42:24z ESP8266 ChipID: 6308294
12/27/19 07:42:24z IoTaWatt 5.0, Firmware version 02_05_02
12/27/19 07:42:24z SPIFFS mounted.
12/27/19 02:42:25 Local time zone: -5:00
12/27/19 02:42:25 Using Daylight Saving Time (BST) when in effect.
12/27/19 02:42:25 device name: IotaWatt
12/27/19 02:42:25 MDNS responder started for hostname IotaWatt
12/27/19 02:42:25 LLMNR responder started for hostname IotaWatt
12/27/19 02:42:25 HTTP server started
12/27/19 02:42:25 timeSync: service started.
12/27/19 02:42:25 statService: started.
12/27/19 02:42:25 Updater: service started. Auto-update class is MINOR
12/27/19 02:42:25 dataLog: service started.
12/27/19 02:42:25 dataLog: Last log entry 12/27/19 02:42:20
12/27/19 02:42:26 WiFi connected. SSID=loumarjr, IP=192.168.8.186, channel=11, RSSI -74db
12/27/19 02:42:26 Updater: Auto-update is current for class MINOR.
12/27/19 02:43:25 historyLog: service started.
12/27/19 02:43:25 historyLog: Last log entry 12/27/19 02:42:00
12/27/19 09:15:59z Real Time Clock is running. Unix time 1577438159
12/27/19 09:15:59z Reset reason: Exception
12/27/19 09:15:59z Trace: 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6]
12/27/19 09:15:59z ESP8266 ChipID: 6308294
12/27/19 09:15:59z IoTaWatt 5.0, Firmware version 02_05_02
12/27/19 09:15:59z SPIFFS mounted.
12/27/19 04:16:00 Local time zone: -5:00
12/27/19 04:16:00 Using Daylight Saving Time (BST) when in effect.
12/27/19 04:16:00 device name: IotaWatt
12/27/19 04:16:00 MDNS responder started for hostname IotaWatt
12/27/19 04:16:00 LLMNR responder started for hostname IotaWatt
12/27/19 04:16:00 HTTP server started
12/27/19 04:16:00 timeSync: service started.
12/27/19 04:16:00 statService: started.
12/27/19 04:16:00 Updater: service started. Auto-update class is BETA
12/27/19 04:16:00 dataLog: service started.
12/27/19 04:16:00 dataLog: Last log entry 12/27/19 04:15:55
12/27/19 04:16:01 WiFi connected. SSID=loumarjr, IP=192.168.8.186, channel=11, RSSI -74db
12/27/19 04:16:01 Updater: Auto-update is current for class BETA.
12/27/19 04:17:00 historyLog: service started.
12/27/19 04:17:00 historyLog: Last log entry 12/27/19 04:15:00
12/27/19 21:17:40 Updater: Invalid response from server. HTTPcode: -4
12/27/19 21:57:13 WiFi disconnected.
12/27/19 22:57:13 WiFi disconnected more than 60 minutes, restarting.
12/28/19 03:57:15z Real Time Clock is running. Unix time 1577505435
12/28/19 03:57:15z Reset reason: Software/System restart
12/28/19 03:57:15z Trace: 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[10], 1:2[11], 9:0[11], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 1:6, 1:3, 1:4, 1:5[21], 21:0, 21:2
12/28/19 03:57:15z ESP8266 ChipID: 6308294
12/28/19 03:57:15z IoTaWatt 5.0, Firmware version 02_05_02
12/28/19 03:57:15z SPIFFS mounted.
12/27/19 22:57:16 Local time zone: -5:00
12/27/19 22:57:16 Using Daylight Saving Time (BST) when in effect.
12/27/19 22:57:16 device name: IotaWatt
12/27/19 22:57:16 MDNS responder started for hostname IotaWatt
12/27/19 22:57:16 LLMNR responder started for hostname IotaWatt
12/27/19 22:57:16 HTTP server started
12/27/19 22:57:16 timeSync: service started.
12/27/19 22:57:16 statService: started.
12/27/19 22:57:16 dataLog: service started.
12/27/19 22:57:16 dataLog: Last log entry 12/27/19 22:57:10
12/27/19 22:57:22 WiFi connected. SSID=loumarjr, IP=192.168.8.186, channel=11, RSSI -72db
12/27/19 22:57:22 Updater: service started. Auto-update class is BETA
12/27/19 22:57:41 Updater: Auto-update is current for class BETA.
12/27/19 22:58:16 historyLog: service started.
12/27/19 22:58:16 historyLog: Last log entry 12/27/19 22:57:00
12/28/19 04:23:02z Real Time Clock is running. Unix time 1577506982
12/28/19 04:23:02z Power failure detected.
12/28/19 04:23:02z Reset reason: External System
12/28/19 04:23:02z ESP8266 ChipID: 6308294
12/28/19 04:23:02z IoTaWatt 5.0, Firmware version 02_05_02
12/28/19 04:23:02z SPIFFS mounted.
12/27/19 23:23:03 Local time zone: -5:00
12/27/19 23:23:03 Using Daylight Saving Time (BST) when in effect.
12/27/19 23:23:03 device name: IotaWatt
12/27/19 23:23:06 MDNS responder started for hostname IotaWatt
12/27/19 23:23:06 LLMNR responder started for hostname IotaWatt
12/27/19 23:23:06 HTTP server started
12/27/19 23:23:06 WiFi connected. SSID=loumarjr, IP=192.168.8.186, channel=11, RSSI -75db
12/27/19 23:23:06 timeSync: service started.
12/27/19 23:23:06 statService: started.
12/27/19 23:23:06 Updater: service started. Auto-update class is BETA
12/27/19 23:23:06 dataLog: service started.
12/27/19 23:23:06 dataLog: Last log entry 12/27/19 23:22:45
12/27/19 23:23:07 Updater: Auto-update is current for class BETA.
12/27/19 23:24:06 historyLog: service started.
12/27/19 23:24:06 historyLog: Last log entry 12/27/19 23:22:100:
Thanks again!!
