Hi
I’ve had my iotawatt up and running since august and its been great until the last few days. Its started disconnecting from wifi really regularly, and then seemed to forget the wifi network entirely - Flashing red-green-green.
I’ve bought it inside so its got a stronger wifi signal and tried to reconnect to the wifi network, I can join the iotawatt network on my, get into the device and set the wifi password, but after that it never completes its startup. It continues the same flash sequence and then eventually turns to solid red. From the iotamsg file I can’t even really see wifi starting up properly.
I’ve tried using the reset option from the config app a few times and rejoined but I have the same results. Any ideas?
iotamsgs.txt (52.0 KB)
