Hi overeasy,
Thanks for the prompt response.
Here are the last 3 resets. Seems like it doesn’t like it’s WIFI but pulled an IP?
12/01/19 19:15:22z Real Time Clock is running. Unix time 1575227722
12/01/19 19:15:22z Reset reason: Software/System restart
12/01/19 19:15:22z Trace: 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[5], 1:2[6], 9:0[6], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[21], 21:0, 21:2
12/01/19 19:15:22z ESP8266 ChipID: 6147434
12/01/19 19:15:22z IoTaWatt 5.0, Firmware version 02_04_02
12/01/19 19:15:22z SPIFFS mounted.
12/01/19 15:15:23 Local time zone: -4:00
12/01/19 15:15:23 Using Daylight Saving Time (BST) when in effect.
12/01/19 15:15:23 device name: IotaWatt
12/01/19 15:15:23 MDNS responder started for hostname IotaWatt
12/01/19 15:15:23 LLMNR responder started for hostname IotaWatt
12/01/19 15:15:23 HTTP server started
12/01/19 15:15:23 timeSync: service started.
12/01/19 15:15:23 statService: started.
12/01/19 15:15:23 dataLog: service started.
12/01/19 15:15:23 dataLog: Last log entry 12/01/19 15:15:20
12/01/19 15:15:28 EmonService: started. url=172.25.3.225:80, node=IotaWatt, interval=10
12/01/19 15:16:23 historyLog: service started.
12/01/19 15:16:23 historyLog: Last log entry 12/01/19 15:15:00
12/01/19 15:16:23 PVoutput: started
12/01/19 16:15:24 WiFi disconnected more than 60 minutes, restarting.
12/01/19 20:15:25z Real Time Clock is running. Unix time 1575231325
12/01/19 20:15:25z Reset reason: Software/System restart
12/01/19 20:15:25z Trace: 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[21], 21:0, 21:2
12/01/19 20:15:25z ESP8266 ChipID: 6147434
12/01/19 20:15:25z IoTaWatt 5.0, Firmware version 02_04_02
12/01/19 20:15:25z SPIFFS mounted.
12/01/19 16:15:26 Local time zone: -4:00
12/01/19 16:15:26 Using Daylight Saving Time (BST) when in effect.
12/01/19 16:15:26 device name: IotaWatt
12/01/19 16:15:26 MDNS responder started for hostname IotaWatt
12/01/19 16:15:26 LLMNR responder started for hostname IotaWatt
12/01/19 16:15:26 HTTP server started
12/01/19 16:15:26 timeSync: service started.
12/01/19 16:15:26 statService: started.
12/01/19 16:15:26 dataLog: service started.
12/01/19 16:15:26 dataLog: Last log entry 12/01/19 16:15:20
12/01/19 16:15:31 EmonService: started. url=172.25.3.225:80, node=IotaWatt, interval=10
12/01/19 16:16:26 historyLog: service started.
12/01/19 16:16:26 historyLog: Last log entry 12/01/19 16:15:00
12/01/19 16:16:26 PVoutput: started
12/01/19 16:29:14 WiFi connected. SSID=Jane, IP=172.25.3.122, channel=11, RSSI -74db
12/01/19 16:29:14 Updater: service started. Auto-update class is MINOR
12/01/19 16:29:14 PVoutput: System madcat, interval 5, freeload mode
12/01/19 16:29:14 PVoutput: Reload status beginning 11/14/19 00:05:00
12/01/19 16:29:16 Updater: Auto-update is current for class MINOR.
12/01/19 16:32:42 EmonService: get input list failing, code: -4
12/01/19 17:15:11 WiFi disconnected.
12/01/19 18:15:11 WiFi disconnected more than 60 minutes, restarting.
12/01/19 22:15:12z Real Time Clock is running. Unix time 1575238512
12/01/19 22:15:12z Reset reason: Software/System restart
12/01/19 22:15:12z Trace: 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:4, 1:5[20], 20:0, 20:1, 20:2, 20:3, 1:6, 1:3, 1:4, 1:5[3], 3:0, 3:3, 1:6, 1:3, 1:4, 1:5[5], 5:0, 1:6, 1:3, 1:4, 1:5[21], 21:0, 21:2
12/01/19 22:15:12z ESP8266 ChipID: 6147434
12/01/19 22:15:12z IoTaWatt 5.0, Firmware version 02_04_02
12/01/19 22:15:12z SPIFFS mounted.
12/01/19 18:15:13 Local time zone: -4:00
12/01/19 18:15:13 Using Daylight Saving Time (BST) when in effect.
12/01/19 18:15:13 device name: IotaWatt
12/01/19 18:15:13 MDNS responder started for hostname IotaWatt
12/01/19 18:15:13 LLMNR responder started for hostname IotaWatt
12/01/19 18:15:13 HTTP server started
12/01/19 18:15:13 timeSync: service started.
12/01/19 18:15:13 statService: started.
12/01/19 18:15:13 dataLog: service started.
12/01/19 18:15:13 dataLog: Last log entry 12/01/19 18:15:10
12/01/19 18:15:18 EmonService: started. url=172.25.3.225:80, node=IotaWatt, interval=10
12/01/19 18:16:13 historyLog: service started.
12/01/19 18:16:13 historyLog: Last log entry 12/01/19 18:15:00
12/01/19 18:16:13 PVoutput: started
