I have had my iotawatt shut down and not log any readings. When I try to access though web browser I get this error “Not found: GET, URI: /” and have to restart to regain access.
Please post the message log.
It stopped working around midnight on 22/3 and only started again when I cycled the power but i lost the data from midnight to 5:45am.
3/15/22 16:54:13 dataLog: service started.
3/15/22 16:54:13 dataLog: Last log entry 03/15/22 16:51:25
3/15/22 16:54:18 historyLog: service started.
3/15/22 16:54:18 historyLog: Last log entry 03/15/22 16:51:00
3/15/22 16:54:18 Grid: Started
3/15/22 16:54:18 Grid: Last log entry 03/15/22 16:51:20
3/15/22 16:54:23 PVoutput: started
3/15/22 06:56:02z Real Time Clock is running. Unix time 1647327362
3/15/22 06:56:02z Reset Reason: Power-fail restart.
3/15/22 06:56:02z ESP8266 ID: 522436, RTC M41T81 (68)
3/15/22 06:56:02z IoTaWatt 5.0, Firmware version 02_07_05
3/15/22 06:56:02z SPIFFS mounted.
3/15/22 16:56:02 Local time zone: +10:00
3/15/22 16:56:02 device name: IotaWatt
3/15/22 16:56:05 Connecting with WiFiManager.
3/15/22 16:57:02 HTTP server started
3/15/22 16:57:03 WiFi connected. SSID=Guest_2, IP=192.168.1.78, channel=1, RSSI -88db
3/15/22 16:57:03 MDNS responder started for hostname IotaWatt
3/15/22 16:57:03 LLMNR responder started for hostname IotaWatt
3/15/22 16:57:03 timeSync: service started.
3/15/22 16:57:03 statService: started.
3/15/22 16:57:03 Updater: service started. Auto-update class is MINOR
3/15/22 16:57:03 dataLog: service started.
3/15/22 16:57:03 dataLog: Last log entry 03/15/22 16:55:45
3/15/22 16:57:04 Updater: Auto-update is current for class MINOR.
3/15/22 16:57:08 historyLog: service started.
3/15/22 16:57:08 historyLog: Last log entry 03/15/22 16:55:00
3/15/22 16:57:08 Grid: Started
3/15/22 16:57:08 Grid: Last log entry 03/15/22 16:55:40
3/15/22 16:57:13 PVoutput: started
3/15/22 16:57:13 PVoutput: System Possum, interval 5, donator mode
3/15/22 16:57:14 PVoutput: Reload status beginning 03/13/22 17:25:00
3/16/22 04:00:42 WiFi disconnected.
3/16/22 04:02:36 WiFi connected. SSID=Guest_2, IP=192.168.1.78, channel=1, RSSI -92db
3/17/22 04:00:42 Updater: Invalid response from server. HTTPcode: -5
3/17/22 04:00:53 WiFi disconnected.
3/17/22 04:02:47 WiFi connected. SSID=Guest_2, IP=192.168.1.78, channel=1, RSSI -89db
3/18/22 04:00:31 WiFi disconnected.
3/18/22 04:02:23 WiFi connected. SSID=Guest_2, IP=192.168.1.78, channel=1, RSSI -91db
3/19/22 04:00:40 WiFi disconnected.
3/19/22 04:02:33 WiFi connected. SSID=Guest_2, IP=192.168.1.78, channel=1, RSSI -92db
3/20/22 04:00:51 WiFi disconnected.
3/20/22 04:02:47 WiFi connected. SSID=Guest_2, IP=192.168.1.78, channel=1, RSSI -92db
3/21/22 04:00:34 WiFi disconnected.
3/21/22 04:02:31 WiFi connected. SSID=Guest_2, IP=192.168.1.78, channel=1, RSSI -93db
3/22/22 04:00:42 WiFi disconnected.
3/22/22 04:02:38 WiFi connected. SSID=Guest_2, IP=192.168.1.78, channel=1, RSSI -90db
3/22/22 19:46:48z Real Time Clock is running. Unix time 1647978408
3/22/22 19:46:48z Reset Reason: Power-fail restart.
3/22/22 19:46:48z ESP8266 ID: 522436, RTC M41T81 (68)
3/22/22 19:46:48z IoTaWatt 5.0, Firmware version 02_07_05
3/22/22 19:46:48z SPIFFS mounted.
3/23/22 05:46:48 Local time zone: +10:00
3/23/22 05:46:48 device name: IotaWatt
3/23/22 05:46:51 HTTP server started
3/23/22 05:46:51 WiFi connected. SSID=Guest_2, IP=192.168.1.78, channel=1, RSSI -91db
3/23/22 05:46:51 MDNS responder started for hostname IotaWatt
3/23/22 05:46:51 LLMNR responder started for hostname IotaWatt
3/23/22 05:46:51 timeSync: service started.
3/23/22 05:46:51 statService: started.
3/23/22 05:46:51 Updater: service started. Auto-update class is MINOR
3/23/22 05:46:51 dataLog: service started.
3/23/22 05:46:52 dataLog: Last log entry 03/22/22 23:46:50
3/23/22 05:46:53 Updater: Auto-update is current for class MINOR.
3/23/22 05:46:56 historyLog: service started.
3/23/22 05:46:56 historyLog: Last log entry 03/22/22 23:46:00
3/23/22 05:47:01 PVoutput: started
3/23/22 05:47:06 PVoutput: System Possum, interval 5, donator mode
3/23/22 05:47:06 PVoutput: Start status beginning 03/22/22 23:45:00
3/23/22 05:47:16 Grid: Started
3/23/22 05:47:16 Grid: Last log entry 03/22/22 23:46:50
3/22/22 20:12:21z Real Time Clock is running. Unix time 1647979941
3/22/22 20:12:21z Reset reason: Software/System restart
3/22/22 20:12:21z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[13], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:3, 10:13
3/22/22 20:12:21z ESP8266 ID: 522436, RTC M41T81 (68)
3/22/22 20:12:21z IoTaWatt 5.0, Firmware version 02_07_05
3/22/22 20:12:21z SPIFFS mounted.
3/23/22 06:12:21 Local time zone: +10:00
3/23/22 06:12:21 device name: IotaWatt
3/23/22 06:12:21 HTTP server started
3/23/22 06:12:21 timeSync: service started.
3/23/22 06:12:21 statService: started.
3/23/22 06:12:21 dataLog: service started.
3/23/22 06:12:21 dataLog: Last log entry 03/23/22 06:12:15
3/23/22 06:12:25 WiFi connected. SSID=Guest_2, IP=192.168.1.78, channel=1, RSSI -92db
3/23/22 06:12:25 MDNS responder started for hostname IotaWatt
3/23/22 06:12:25 LLMNR responder started for hostname IotaWatt
3/23/22 06:12:25 Updater: service started. Auto-update class is MINOR
3/23/22 06:12:26 historyLog: service started.
3/23/22 06:12:26 historyLog: Last log entry 03/23/22 06:12:00
3/23/22 06:12:26 Updater: Auto-update is current for class MINOR.
3/23/22 06:12:26 Grid: Started
3/23/22 06:12:26 Grid: Last log entry 03/23/22 06:12:15
3/23/22 06:12:31 PVoutput: started
3/23/22 06:12:31 PVoutput: System Possum, interval 5, donator mode
3/23/22 06:12:32 PVoutput: Start status beginning 03/23/22 06:10:00
3/22/22 20:21:30z Real Time Clock is running. Unix time 1647980490
3/22/22 20:21:30z Reset Reason: Power-fail restart.
3/22/22 20:21:30z ESP8266 ID: 522436, RTC M41T81 (68)
3/22/22 20:21:30z IoTaWatt 5.0, Firmware version 02_07_05
3/22/22 20:21:30z SPIFFS mounted.
3/23/22 06:21:30 Local time zone: +10:00
3/23/22 06:21:30 device name: IotaWatt
3/23/22 06:21:33 HTTP server started
3/23/22 06:21:33 WiFi connected. SSID=Guest_2, IP=192.168.1.78, channel=1, RSSI -91db
3/23/22 06:21:33 MDNS responder started for hostname IotaWatt
3/23/22 06:21:33 LLMNR responder started for hostname IotaWatt
3/23/22 06:21:33 timeSync: service started.
3/23/22 06:21:33 statService: started.
3/23/22 06:21:33 Updater: service started. Auto-update class is MINOR
3/23/22 06:21:33 dataLog: service started.
3/23/22 06:21:34 dataLog: Last log entry 03/23/22 06:13:10
3/23/22 06:21:37 Updater: Auto-update is current for class MINOR.
3/23/22 06:21:38 historyLog: service started.
3/23/22 06:21:38 historyLog: Last log entry 03/23/22 06:13:00
3/23/22 06:21:38 Grid: Started
3/23/22 06:21:38 Grid: Last log entry 03/23/22 06:13:10
3/23/22 06:21:43 PVoutput: started
3/23/22 06:21:43 PVoutput: System Possum, interval 5, donator mode
3/23/22 06:21:44 PVoutput: Start status beginning 03/23/22 06:10:00
3/22/22 20:28:37z Real Time Clock is running. Unix time 1647980917
3/22/22 20:28:37z Reset Reason: Power-fail restart.
3/22/22 20:28:37z ESP8266 ID: 522436, RTC M41T81 (68)
3/22/22 20:28:37z IoTaWatt 5.0, Firmware version 02_07_05
3/22/22 20:28:37z SPIFFS mounted.
3/23/22 06:28:37 Local time zone: +10:00
3/23/22 06:28:37 device name: IotaWatt
3/23/22 06:28:40 HTTP server started
3/23/22 06:28:40 WiFi connected. SSID=Guest_2, IP=192.168.1.78, channel=1, RSSI -89db
3/23/22 06:28:40 MDNS responder started for hostname IotaWatt
3/23/22 06:28:40 LLMNR responder started for hostname IotaWatt
3/23/22 06:28:40 timeSync: service started.
3/23/22 06:28:40 statService: started.
3/23/22 06:28:40 Updater: service started. Auto-update class is MINOR
3/23/22 06:28:40 dataLog: service started.
3/23/22 06:28:40 dataLog: Last log entry 03/23/22 06:25:40
3/23/22 06:28:42 Updater: Auto-update is current for class MINOR.
3/23/22 06:28:44 Grid: Started
3/23/22 06:28:44 Grid: Last log entry 03/23/22 06:25:40
3/23/22 06:28:45 historyLog: service started.
3/23/22 06:28:45 historyLog: Last log entry 03/23/22 06:25:00
3/23/22 06:28:49 PVoutput: started
3/23/22 06:28:50 PVoutput: System Possum, interval 5, donator mode
3/23/22 06:28:51 PVoutput: Start status beginning 03/23/22 06:25:00
3/23/22 06:31:24 PVoutput: System Possum, interval 5, donator mode
3/23/22 06:31:25 PVoutput: Reload status beginning 03/22/22 00:05:00
3/23/22 07:28:40 timeSync: adjusting RTC by 3564
3/22/22 23:15:10z Real Time Clock is running. Unix time 1647990910
3/22/22 23:15:10z Reset reason: Software/System restart
3/22/22 23:15:10z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[13], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4]
3/22/22 23:15:10z ESP8266 ID: 522436, RTC M41T81 (68)
3/22/22 23:15:10z IoTaWatt 5.0, Firmware version 02_07_05
3/22/22 23:15:10z SPIFFS mounted.
3/23/22 09:15:10 Local time zone: +10:00
3/23/22 09:15:10 device name: IotaWatt
3/23/22 09:15:10 HTTP server started
3/23/22 09:15:10 timeSync: service started.
3/23/22 09:15:10 statService: started.
3/23/22 09:15:10 dataLog: service started.
3/23/22 09:15:10 dataLog: Last log entry 03/23/22 08:21:35
3/23/22 09:15:14 WiFi connected. SSID=Guest_2, IP=192.168.1.78, channel=1, RSSI -92db
3/23/22 09:15:14 MDNS responder started for hostname IotaWatt
3/23/22 09:15:14 LLMNR responder started for hostname IotaWatt
3/23/22 09:15:14 Updater: service started. Auto-update class is MINOR
3/23/22 09:15:15 historyLog: service started.
3/23/22 09:15:15 historyLog: Last log entry 03/23/22 08:21:00
3/23/22 09:15:15 Updater: Auto-update is current for class MINOR.
3/23/22 09:15:17 Grid: Started
3/23/22 09:15:17 Grid: Last log entry 03/23/22 08:21:35
3/23/22 09:15:20 PVoutput: started
3/23/22 09:15:21 PVoutput: System Possum, interval 5, donator mode
3/23/22 09:15:22 PVoutput: Start status beginning 03/23/22 08:20:00
This looks like an SDcard issue. It could be the card, or it could be the card holder. The first step would be to replace the SDcard and see what happens.
Unfortunately you are halfway around the world. In the interest of expediency, do you have or can you get an 8GB (or larger up to 32GB) SDcard? If so, I will work through that with you. If not, I can send you a card.
Ok. So I pulled the micro sd and cleaned it. Was going good until now so I will get a new card tomorrow. Can you run me though setting up the new card please.
Never mind. The “How to set up new sd card” post was at the bottom of my screen:)
Ok. How do I recover the previous data?
If it is recoverable, it is all in the directory /iotawatt on the old card. You can try copying that from the old card to the new, replacing what is there if you have powered the iotawatt with the new card. If any of the files in the directory appear damaged, you will have lost the history
A post was split to a new topic: Non-specific problem post
