I have the same issue… meaning to post but had not have the time to do so
I get a restart at different time… It happens with the uploader on and off:
1/12/22 18:12:39 HTTP server started
1/12/22 18:12:39 influxDB_v2: Starting, interval:5, url:http://XXXXXXXXXX:8086
1/12/22 18:12:39 timeSync: service started.
1/12/22 18:12:39 statService: started.
1/12/22 18:12:39 dataLog: service started.
1/12/22 18:12:39 dataLog: Last log entry 01/12/22 18:12:35
1/12/22 18:12:44 historyLog: service started.
1/12/22 18:12:44 historyLog: Last log entry 01/12/22 18:12:00
1/12/22 18:12:44 battery: Started
1/12/22 18:12:44 battery: Last log entry 01/12/22 18:12:35
1/12/22 18:12:44 grid: Started
1/12/22 18:12:44 grid: Last log entry 01/12/22 18:12:35
1/12/22 18:12:47 WiFi connected. SSID=XXXXXXXXXX, IP=XXXXXXXXXX, channel=11, RSSI -75db
1/12/22 18:12:47 MDNS responder started for hostname XXXXXXXXXX
1/12/22 18:12:47 LLMNR responder started for hostname XXXXXXXXXX
1/12/22 18:12:47 Updater: service started. Auto-update class is ALPHA
1/12/22 18:12:47 influxDB_v2: Resume posting 01/12/22 18:09:40
1/12/22 18:12:50 Updater: Auto-update is current for class ALPHA.
1/12/22 18:14:45 Heap memory has degraded below safe minimum, restarting.
1/13/22 00:14:46z Real Time Clock is running. Unix time 1642032886
1/13/22 00:14:46z Reset reason: Software/System restart
1/13/22 00:14:46z Trace: 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4], 1:6[6], 1:1[12], 1:2[14], 9:0[14], 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
1/13/22 00:14:46z ESP8266 ID: 16295192, RTC PCF8523 (68)
1/13/22 00:14:46z IoTaWatt 5.0, Firmware version 02_07_05
1/13/22 00:14:46z SPIFFS mounted.
1/12/22 18:14:46 Local time zone: -6:00, using DST/BST when in effect.
1/12/22 18:14:46 device name: XXXXXXXXXX
1/12/22 18:14:46 HTTP server started
1/12/22 18:14:46 influxDB_v2: Starting, interval:5, url:http://XXXXXXXXXX:8086
1/12/22 18:14:46 timeSync: service started.
1/12/22 18:14:46 statService: started.
1/12/22 18:14:46 dataLog: service started.
1/12/22 18:14:47 dataLog: Last log entry 01/12/22 18:14:45
1/12/22 18:14:51 historyLog: service started.
1/12/22 18:14:51 historyLog: Last log entry 01/12/22 18:14:00
1/12/22 18:14:51 battery: Started
1/12/22 18:14:51 battery: Last log entry 01/12/22 18:14:45
1/12/22 18:14:51 grid: Started
1/12/22 18:14:51 grid: Last log entry 01/12/22 18:14:45
1/12/22 18:15:05 WiFi connected. SSID=XXXXXXXXXX, IP=XXXXXXXXXX, channel=11, RSSI -75db
1/12/22 18:15:05 MDNS responder started for hostname XXXXXXXXXX
1/12/22 18:15:05 LLMNR responder started for hostname XXXXXXXXXX
1/12/22 18:15:05 Updater: service started. Auto-update class is ALPHA
1/12/22 18:15:08 influxDB_v2: Resume posting 01/12/22 18:13:50
1/12/22 18:15:14 Updater: Auto-update is current for class ALPHA.
1/12/22 18:15:33 Heap memory has degraded below safe minimum, restarting.
1/13/22 00:15:34z Real Time Clock is running. Unix time 1642032934
1/13/22 00:15:34z Reset reason: Software/System restart
1/13/22 00:15:34z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[12], 1:2[14], 9:0[14], 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
1/13/22 00:15:34z ESP8266 ID: 16295192, RTC PCF8523 (68)
1/13/22 00:15:34z IoTaWatt 5.0, Firmware version 02_07_05
1/13/22 00:15:34z SPIFFS mounted.
1/12/22 18:15:34 Local time zone: -6:00, using DST/BST when in effect.
1/12/22 18:15:34 device name: XXXXXXXXXX
1/12/22 18:15:34 HTTP server started
1/12/22 18:15:34 influxDB_v2: Starting, interval:5, url:http://XXXXXXXXXX:8086
1/12/22 18:15:34 timeSync: service started.
1/12/22 18:15:34 statService: started.
1/12/22 18:15:34 dataLog: service started.
1/12/22 18:15:35 dataLog: Last log entry 01/12/22 18:15:30
1/12/22 18:15:39 historyLog: service started.
1/12/22 18:15:39 historyLog: Last log entry 01/12/22 18:15:00
1/12/22 18:15:39 WiFi connected. SSID=XXXXXXXXXX, IP=XXXXXXXXXX, channel=11, RSSI -75db
1/12/22 18:15:39 MDNS responder started for hostname XXXXXXXXXX
1/12/22 18:15:39 LLMNR responder started for hostname XXXXXXXXXX
1/12/22 18:15:39 Updater: service started. Auto-update class is ALPHA
1/12/22 18:15:39 battery: Started
1/12/22 18:15:39 battery: Last log entry 01/12/22 18:15:30
1/12/22 18:15:40 grid: Started
1/12/22 18:15:40 grid: Last log entry 01/12/22 18:15:30
1/12/22 18:15:46 Updater: Auto-update is current for class ALPHA.
1/12/22 18:17:49 influxDB_v2: Resume posting 01/12/22 18:13:50
1/12/22 18:17:56 Heap memory has degraded below safe minimum, restarting.
1/13/22 00:17:57z Real Time Clock is running. Unix time 1642033077
1/13/22 00:17:57z Reset reason: Software/System restart
1/13/22 00:17:57z Trace: 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 31:93, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
1/13/22 00:17:57z ESP8266 ID: 16295192, RTC PCF8523 (68)
1/13/22 00:17:57z IoTaWatt 5.0, Firmware version 02_07_05
1/13/22 00:17:57z SPIFFS mounted.
1/12/22 18:17:57 Local time zone: -6:00, using DST/BST when in effect.
1/12/22 18:17:57 device name: XXXXXXXXXX
1/12/22 18:17:57 HTTP server started
1/12/22 18:17:57 influxDB_v2: Starting, interval:5, url:http://XXXXXXXXXX:8086
1/12/22 18:17:57 timeSync: service started.
1/12/22 18:17:57 statService: started.
1/12/22 18:17:57 dataLog: service started.
1/12/22 18:17:57 dataLog: Last log entry 01/12/22 18:17:55
1/12/22 18:18:02 historyLog: service started.
1/12/22 18:18:02 historyLog: Last log entry 01/12/22 18:17:00
1/12/22 18:18:02 WiFi connected. SSID=XXXXXXXXXX, IP=XXXXXXXXXX, channel=11, RSSI -74db
1/12/22 18:18:02 MDNS responder started for hostname XXXXXXXXXX
1/12/22 18:18:02 LLMNR responder started for hostname XXXXXXXXXX
1/12/22 18:18:02 Updater: service started. Auto-update class is ALPHA
1/12/22 18:18:02 battery: Started
1/12/22 18:18:02 battery: Last log entry 01/12/22 18:17:55
1/12/22 18:18:03 grid: Started
1/12/22 18:18:03 grid: Last log entry 01/12/22 18:17:55
1/12/22 18:18:06 influxDB_v2: Resume posting 01/12/22 18:13:50
1/12/22 18:18:12 Updater: Auto-update is current for class ALPHA.
1/12/22 18:18:31 Heap memory has degraded below safe minimum, restarting.
1/13/22 00:18:32z Real Time Clock is running. Unix time 1642033112
1/13/22 00:18:32z Reset reason: Software/System restart
1/13/22 00:18:32z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[10], 1:2[11], 9:0[11], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
1/13/22 00:18:32z ESP8266 ID: 16295192, RTC PCF8523 (68)
1/13/22 00:18:32z IoTaWatt 5.0, Firmware version 02_07_05
1/13/22 00:18:32z SPIFFS mounted.
1/12/22 18:18:32 Local time zone: -6:00, using DST/BST when in effect.
1/12/22 18:18:32 device name: XXXXXXXXXX
1/12/22 18:18:32 HTTP server started
1/12/22 18:18:32 influxDB_v2: Starting, interval:5, url:http://XXXXXXXXXX:8086
1/12/22 18:18:32 timeSync: service started.
1/12/22 18:18:32 statService: started.
1/12/22 18:18:32 dataLog: service started.
1/12/22 18:18:32 dataLog: Last log entry 01/12/22 18:18:30
1/12/22 18:18:37 historyLog: service started.
1/12/22 18:18:37 historyLog: Last log entry 01/12/22 18:18:00
1/12/22 18:18:37 Updater: service started. Auto-update class is ALPHA
1/12/22 18:18:37 battery: Started
1/12/22 18:18:37 battery: Last log entry 01/12/22 18:18:30
1/12/22 18:18:37 grid: Started
1/12/22 18:18:37 grid: Last log entry 01/12/22 18:18:30
1/12/22 18:18:37 influxDB_v2: Resume posting 01/12/22 18:13:50
1/12/22 18:18:38 WiFi connected. SSID=XXXXXXXXXX, IP=XXXXXXXXXX, channel=11, RSSI -72db
1/12/22 18:18:38 MDNS responder started for hostname XXXXXXXXXX
1/12/22 18:18:38 LLMNR responder started for hostname XXXXXXXXXX
1/12/22 18:18:39 Updater: Auto-update is current for class ALPHA.
1/15/22 03:05:35 WiFi disconnected.
1/15/22 03:06:14 WiFi connected. SSID=XXXXXXXXXX, IP=XXXXXXXXXX, channel=6, RSSI -85db
1/17/22 22:03:19 Heap memory has degraded below safe minimum, restarting.
1/18/22 04:03:21z Real Time Clock is running. Unix time 1642478601
1/18/22 04:03:21z Reset reason: Software/System restart
1/18/22 04:03:21z Trace: 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 31:93, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
1/18/22 04:03:21z ESP8266 ID: 16295192, RTC PCF8523 (68)
1/18/22 04:03:21z IoTaWatt 5.0, Firmware version 02_07_05
1/18/22 04:03:21z SPIFFS mounted.
1/17/22 22:03:21 Local time zone: -6:00, using DST/BST when in effect.
1/17/22 22:03:21 device name: XXXXXXXXXX
1/17/22 22:03:21 HTTP server started
1/17/22 22:03:21 influxDB_v2: Starting, interval:5, url:http://XXXXXXXXXX:8086
1/17/22 22:03:21 timeSync: service started.
1/17/22 22:03:21 statService: started.
1/17/22 22:03:21 dataLog: service started.
1/17/22 22:03:22 dataLog: Last log entry 01/17/22 22:03:15
1/17/22 22:03:26 historyLog: service started.
1/17/22 22:03:26 historyLog: Last log entry 01/17/22 22:03:00
1/17/22 22:03:26 battery: Started
1/17/22 22:03:26 battery: Last log entry 01/17/22 22:03:15
1/17/22 22:03:26 grid: Started
1/17/22 22:03:26 grid: Last log entry 01/17/22 22:03:15
1/17/22 22:03:27 Updater: service started. Auto-update class is ALPHA
1/17/22 22:03:28 WiFi connected. SSID=XXXXXXXXXX, IP=XXXXXXXXXX, channel=11, RSSI -72db
1/17/22 22:03:28 MDNS responder started for hostname XXXXXXXXXX
1/17/22 22:03:28 LLMNR responder started for hostname XXXXXXXXXX
1/17/22 22:03:28 influxDB_v2: Resume posting 01/17/22 22:02:30
1/17/22 22:03:30 Updater: Auto-update is current for class ALPHA.
1/18/22 20:05:44 Updater: Invalid response from server. HTTPcode: -14
