Since most of the USA user will use a Split Phase system (120v) with a single phase system (220v), How IOTaWatt is calculating all parameters if it only uses one split phase of the 220Vac supply? It is wier that this system does not monitor both split phase voltage references or at least the main phase circuit voltage with the L1, L2 and Neutral… Reference voltage is crucial for energy calculation and can not be taken as a given constant… It is actually a variable as well as the actual current variables consumed in both split phases… In Split phase circuits, estimating the voltage from L1 to Neutral, based on the Voltage reading in L2 to neutral, is not a good approach for accuracy in the estimation or calculation. Be careful to trust something that don follow the very basic laws in electrical circuits…
Other point to take in consideration is the Actual Calibration of the System… The system accuracy of the actual Energy calculator depends on the full calibration of all inputs with their respective current CT sensors…Many CT sensors has their own calibration characterization chart and many others has a zaro and span adjustments to properly calibrate the sensor to ensure the sensor is with the accuracy and within specifications… This means that when it says it is passing 1 Amp through the wire it is actually passing 1.0 Amps and not 1.25, or 0 Amps… This readings greatly depend on the Wire Size, the tension or Voltage and the induction noise around the CT Pick Up sensor affecting the CT reading or accuracy. The same applies to each input of the system. The complete calibration by loop, meaning each input channel must be verified by loop or with all its components connected together (Cable, CT, Reference Voltage)…
Usually, this systems developed or customized as DiY, do not follow strict quality standards. They serve their purposes, as a for reference only. If you base your economic decisions in a instrument that does not offer good Quality control standards on its design and installations, then I suggest to always take in consideration that your reading might be biased by incorrect readings.
Established that point, I believe this system serve a purpose and cover the energy measuring needs for the average energy consumer… whose goal is to have an idea or an approximation of their energy consumption…
Nop, I am not a Sense, Schneider, Wibeee, or any other brand representative… I am just an average energy consumer…
I would like to see a furder hardware approach to monitor loads. Perhaps, focus on smart power outlets connected by WiFi, Power Bus, or any other communication ways. The way the system is designed, is not flexible. 14 inputs just monitor 14 circuits, and only there amperage. If you have 10 equipment connected to a circuit, then which one is On consuming energy? If you can use Smart Power outlets, then you might be able to isolate each equipment connected to every outlet… improving the monitoring to the equipment base system instead of circuit base approach… Of course this could means the incursion to new ways of automation bus like, ModBus, DeviceNet, and many other Bus Communication technology used in this days for Industrial Automation, and DAQs, SCADA, PMS, MES… applied to Home Automation…
Many other systems in the market, use Smart algorithms to detect and create a DataBase of the equipments bases on usage and behavior of each equipment. Using the help of the user, but annoying them with excessive messages just to try to acquire the knowledge to Identify the equipment. It is not a good approach… but the cheaper one. One alternative is to incorporate an ID of every equipment based on the out side where it is connected. This is actually very close to be accomplished by the Smart Outlets and Switches… Those tou can assign a description for the equipment it serves to easely ID them in ab App. Why not to adopt this approach and do some changes to ensure your Energy Management system integrates in this Home Automation approach.
The purpose of a value added system in Energy Monitoring, is to create an awareness of the proper energy saving approach for the average energy consumer. Where the consumer can target the specific Equipment in their home that need to take corrective actions with a proper Energy Management strategy… Where in my home is the 20% of the equipment that is Consuming the 80% of the Energy that is draining my pockets…
Start building on this type of hardware will lead you in a wrong path where is not an exit and will require to trough everything to the garbage and start over in the drawing board for a more flexible hardware approach.
However, it is a good starting point for the average consumer. I am not trying to dismiss this system. I am trying to make the click for those working on the development of this project, to start thinking and designing based on a more flexible and accurate approach. Targeting Energy efficiency and Energy cost reduction. This first steps in this project should be the inspiration for something bigger. Please, just done let the system at this level.
By the way, I am truly considering to acquiring the system.
) I also use it to help with home automations, such as sending notifications whenever my washer or dryer complete a laundry cycle via the Hubitat integration that I wrote some time ago.
