The log for the period in question is below. The last entry/line in this log shows the same date/time (09/02/23 22:37:00) the problem occurred. I also checked the other period where I was receiving null entries and the log clearly shows “Power failure” so I’ll leave it at that,
9/03/23 02:37:43z Real Time Clock is running. Unix time 1693708663
9/03/23 02:37:43z Reset reason: Software Watchdog
9/03/23 02:37:43z Trace: 34:10[3], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[2], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10, 25:18, 25:19, 25:20, 10:52, 10:54, 10:56, 25:20, 25:40, 25:41, 25:42, 25:41, 25:50, 25:51
9/03/23 02:37:43z ESP8266 ID: 499544, RTC M41T81 (68)
9/03/23 02:37:43z IoTaWatt 5.0, Firmware version 02_08_02
9/03/23 02:37:43z SPIFFS mounted.
9/02/23 22:37:43 Local time zone: -5:00, using DST/BST when in effect.
9/02/23 22:37:43 device name: IotaWatt
9/02/23 22:37:43 HTTP server started
9/02/23 22:37:43 timeSync: service started.
9/02/23 22:37:43 statService: started.
9/02/23 22:37:43 dataLog: service started.
9/02/23 22:37:46 IotaLog: file damaged /iotawatt/iotalog.log
9/02/23 22:37:46 IotaLog: Creating diagnostic file.
9/03/23 03:08:05z Real Time Clock is running. Unix time 1693710485
9/03/23 03:08:05z Reset reason: Exception
9/03/23 03:08:05z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[14], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[19], 1:6[4]
9/03/23 03:08:05z ESP8266 ID: 499544, RTC M41T81 (68)
9/03/23 03:08:05z IoTaWatt 5.0, Firmware version 02_08_02
9/03/23 03:08:05z SPIFFS mounted.
9/02/23 23:08:05 Local time zone: -5:00, using DST/BST when in effect.
9/02/23 23:08:05 device name: IotaWatt
9/02/23 23:08:05 HTTP server started
9/02/23 23:08:05 timeSync: service started.
9/02/23 23:08:05 statService: started.
9/02/23 23:08:05 dataLog: service started.
9/02/23 23:08:07 IotaLog: file damaged /iotawatt/iotalog.log
9/02/23 23:08:07 IotaLog: Creating diagnostic file.
9/03/23 00:00:34 IotaLog: Deleting /iotawatt/iotalog.log and restarting.
9/03/23 04:00:39z Real Time Clock is running. Unix time 1693713639
9/03/23 04:00:39z Reset reason: Software/System restart
9/03/23 04:00:39z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[19], 1:6[4]
9/03/23 04:00:39z ESP8266 ID: 499544, RTC M41T81 (68)
9/03/23 04:00:39z IoTaWatt 5.0, Firmware version 02_08_02
9/03/23 04:00:39z SPIFFS mounted.
9/03/23 00:00:39 Local time zone: -5:00, using DST/BST when in effect.
9/03/23 00:00:39 device name: IotaWatt
9/03/23 00:00:39 HTTP server started
9/03/23 00:00:39 timeSync: service started.
9/03/23 00:00:39 statService: started.
9/03/23 00:00:39 dataLog: service started.
9/03/23 00:00:39 dataLog: New current log created.
9/03/23 00:00:40 dataLog: Last history entry: 09/02/23 22:37:00
9/03/23 00:00:43 WiFi connected. SSID=CKZ_2HA, IP=192.168.1.139, channel=3, RSSI -47db
9/03/23 00:00:43 Updater: service started. Auto-update class is MINOR
9/03/23 00:00:44 Updater: Auto-update is current for class MINOR.
9/03/23 00:01:47 historyLog: service started.
9/03/23 00:01:47 historyLog: Last log entry 09/02/23 22:37:00
