Noticed my new IotaWatt went offline at 11:57am today. Rebooted it, nothing. Then I checked the status light and it is GREEN-RED-RED which is a failed SD card or slot. SD is fine, so according to their own troubleshooting the device is now faulty.
HOWEVER, the iotamsgs.txt file has a final message of: 12/07/22 11:56:43 Updater: Firmware updated, restarting.
Surely this is not a coincidence. Did a new firmware just kill my new IotaWatt? I have had it less than 2 weeks! I configured it when it arrived, then it sat on my desk until it was installed in a new house install only 2 days ago! Now it’s dead
One of my IotaWatts hit this last night as well – let me know if you’d like me to try anything. I tried reformatting the SD card and copying the files back over to it – the 02_08_00 and DOWNLOAD directories couldn’t be copied, maybe due to corruption?
Happy to help debug/try out builds/etc. Let me know if there’s anything I can do.
Can you tell me when you got this unit? i.e. is it new? There is a sticker on the back of the PCB, if you have it opened, can you provide the two numbers on the top line please?
FYI, I’ve just bought a 5 pack of some Samsung 32GB SD cards to serve as dedicated replacements for my IotaWatts – if they work, I’ll reply here and let you know what model.
I reset auto-update MINOR to 02_07_05 to stop anyone else from updating. I’ve removed that release from the website for now. If you want to install it, set your auto-update to none and follow the instructions for manual update. You should already have the release file on your old card in the download directory.
Looks like I got hit by this as well. Device stopped responding a couple of days ago, went to look at it. Red Green Green. Took apart, grabbed the SD. It’s ok, but copied all the files to a new larger SD.
12/07/22 06:59:09 Updater: Update from 02_07_05 to 02_08_00
12/07/22 06:59:09 Updater: download 02_08_00
12/07/22 06:59:23 Updater: Release downloaded 13949ms, size 968904
12/07/22 06:59:39 Updater: signature verified
12/07/22 06:59:48 Updater: firmware upgraded to version 02_08_00
12/07/22 06:59:48 Updater: Firmware updated, restarting.
And now it’s dull red, even with new SD. Plugged into computer, trying to see if the serial port is putting anything out, nothing. Reset device, I see the ESP flash blue for a millisecond, but nothing else, and no output on the console.
I have had my device since about July and it has never failed - 2 days ago it shutdown and I got the GRR LED warning when I rebooted several hours later after realising it was down.
It has now downgraded to the previous firmware and is working fine - just thought I’d mention it as you’d suggested it was only recent devices impacted. If you want device ID / SD Card type I can open it up and get them.
